Re: Quickest way to remove rear leaf springs...
[Re: Blakcharger440]
#436193
08/12/09 09:56 PM
08/12/09 09:56 PM
Posts: 1,261 ILL
mark7171
ILL
#436194
08/12/09 10:24 PM
08/12/09 10:24 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
If your installing the Cal-Trac's then the easiest will be to jackup the car, Jackstands under the Front part of the frame rails. Pull the 8 Bolts for the (4 for each)rear Hanger. Disassemble the Shackle, push the old bushing out (Big C-Clamp and Pipe), Press the new bushing in. Buy new U-BOLTS before you attempt to drop the axle. Hack Saw, Sawzall, Torch the old U-Bolts off. The reason being is the Nuts on the U-Bolts are stamped and are a PITA to remove without Air Tools. Good Luck..
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
#436199
08/13/09 02:51 AM
08/13/09 02:51 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Do one side completely, then the other. That way you don't have to fight the rear end as much.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#436200
08/13/09 04:06 AM
08/13/09 04:06 AM
Posts: 79 grant louisiana
mayhem148
grant louisiana
the higher you get the car in the air to work on the better. it sucks being cramped underneath.
[Re: RoyceFlo73]
#436203
08/13/09 11:06 AM
08/13/09 11:06 AM
Posts: 4,799 ILL
MLR426
ILL
A torch.
haha, beat me to it.
Beat me to it also ![](/ubbthreads/images/graemlins/weld.gif)
logan426
[Re: RapidRobert]
#436206
08/14/09 08:04 AM
08/14/09 08:04 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Just did mine again.I out stands under the frame in frt on the frt hangers.Leave the floor jack under the center of the rear.Then i undo the Ubolts and shocks.The rear just sits on the jack,Then undo the spring hangers.Its easier to R&R the whole spring to change the bushings.Reinstall spring a helper is great for that.Let the rear down till it rests on the spring and install the ubolts and plates.Did mine with changing bushings in about an hour on the ground.Rocky
Chrysler Firepower
