Re: Bias Tire size to Radial size cross reference
[Re: SPWC]
#436167
08/12/09 09:21 PM
08/12/09 09:21 PM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The old bias ply tires were very tall by today's radial standards. It is often difficult to find a newer radial tire that has as tall a sidwall as the old tires had. Here is how your 235/80 compares to the 235/75; the 235 is the tire width in mm. The 75 or 80 is the sidewall heigth which is a percentage of the tire width. So, the 80 means that the sidewall is 80% of 235 or 188mm tall. The 75 is 75% of 235 or 176mm. The 235/75 tire will have about 12mm shorter sidewall than the 235/80 tire. Now, I have found that although based on actual measurements like 235mm and 80%, some tires vary in size from one brand to another just as much as the old F78s and G60s did. Good luck, I hope this helps.
Master, again and still
[Re: SPWC]
#436170
08/13/09 12:41 AM
08/13/09 12:41 AM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
Here's an unused spare on EBAY, now you need to find 3 more.
[Re: 6bblgt]
#436172
08/13/09 04:09 PM
08/13/09 04:09 PM
Posts: 4,102 Cochise County Arizona
SPWC
Nope I only need to find 2 more,I already have one of those spares exactly like it.Thanks for the heads up
[Re: 6bblgt]
#436175
08/14/09 08:14 AM
08/14/09 08:14 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I ran 225 75 15s on my 57 Chrysler and was happy with them.You should be good with that or the 235s.I had 235s on the 66 Imperial.Rocky
Chrysler Firepower
