Potential problem after rebuild? #436058
08/12/09 07:05 PM
08/12/09 07:05 PM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
Heads were pulled for new stealths after rebuild on my 383. I noticed a white deposit on two valves, one on each head and noticed they were on the 7, and 8 plugs (rear of motor) What would cause this? Attached is photo of one.
Re: Potential problem after rebuild? [Re: ireland383] #436059
08/12/09 11:19 PM
08/12/09 11:19 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
ive seen this before on many heads , are you running a fuel additive?.
Re: Potential problem after rebuild? [Re: moparsquid] #436060
08/13/09 06:28 AM
08/13/09 06:28 AM
Suffolk,VA
I
I
Suffolk,VA
No fuel additive. I did some more research and It's normal to have a white deposit on the exhaust valves. Thanks
Re: Potential problem after rebuild? [Re: ireland383] #436061
08/13/09 08:39 AM
08/13/09 08:39 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Back in the day after a run down the hiway if the engines were running good the insides of the tail pipes would be white.
Even now if I run left over race gas mix in the garden tractor I have a white exhaust outlet.
