Re: My Tow Rig...
[Re: 70dusterjohn]
#435815
08/12/09 04:42 PM
08/12/09 04:42 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Sounds fun... Mind you your truck has electronic cluster and you will have to have either an electronic speedo/cluster made for it, or you will have to make a cable driven cluster retro fitted for your truck, All going to add up in the "no funds" dept. If you have some parts and pieces laying around, Id do it man, sounds fun. Your Truck also has a rear abs sensor too. You can basically gut the truck, and turn it back into a basic old truck with new skins, but I dont know how you will keep the A/C, Headlights, And power door to work, You might want to get a wireing diagram to look at.
Kasey
Re: My Tow Rig...
[Re: Moparnut426]
#435816
08/12/09 04:47 PM
08/12/09 04:47 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Sounds like a great idea if you can pull it off.
Re: My Tow Rig...
[Re: ETASPEN]
#435818
08/12/09 04:51 PM
08/12/09 04:51 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
For what it will cost in the long run to make it work, not to mention the emissions issues if your state has inspections, you could buy a good used 2500 Ram. I've seen 95-99 2500 Diesel Rams on Ebay for about 8-13K depending on condition. Heck, someone out there may even want to TRADE their diesel for a nice gas truck like yours. ![](/ubbthreads/images/graemlins/Twocents.gif)
I'm Gumby dammit!
Re: My Tow Rig...
[Re: 70dusterjohn]
#435820
08/12/09 05:31 PM
08/12/09 05:31 PM
Moparnut426
There really is no way to keep the computer because too many sensors rely on info to make them work, IE cam, crank, rear vehicle speed, trany output, tranny input, and that has a fully electronic MIC, mechanical instrument cluster, It also is kinda a brain of its own. If you plan on doing this, I dont see any problems with the custom wireing hot rod kit. The headlight you can probably still wire into the factory switch, and fuse pannes, but that truck also has a Power distrubution center which has either a front controll module, or a tipm , totally integrated power module, on it also. So you will be gutting the truck. You will be losing probably 500lbs of wireing off the truck.
Kasey
Re: My Tow Rig...
[Re: 70dusterjohn]
#435822
08/12/09 06:47 PM
08/12/09 06:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'd rethink this..I have a '02 Ram like yours with 125 on the clock and it's still doing great.If anything,I'd look at swapping a 5.7 late model Hemi in if you really need to upgrade or put in a 4.7HO engine.
Re: My Tow Rig...
[Re: Chris2581]
#435823
08/12/09 07:28 PM
08/12/09 07:28 PM
Moparnut426
There is no "HO" 4.7, they just have "HO" programing in the jeep grand cherokee. All parts from a 4.7 in a truck will directly interchange with a 4.7 in the jeeps. They just have better programing, and different injectors, so that would be a waste of time. I dont think there would be a problem with your swap even with the gutting.
Id do it.
Kasey
Re: My Tow Rig...
[Re: Chris2581]
#435824
08/12/09 07:37 PM
08/12/09 07:37 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
I looked into the 5.7 but to be honest my friend tows his car with a 5.7 and on hills I can out pull him with my little 4.7.. I just want to always have my foot in it to pull up small grades let alone big hills. And before you say it, his car and trailer weight is less than mine..same truck just 5.7.. ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: My Tow Rig...
[Re: Moparnut426]
#435825
08/12/09 07:49 PM
08/12/09 07:49 PM
Chris2581
Jacksonville, FL
Id do it.
Kasey
Camshafts are different,and IIRC,the intake is too.
Re: My Tow Rig...
[Re: 70dusterjohn]
#435827
08/12/09 09:13 PM
08/12/09 09:13 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Its a 03 truck, its not that old and the mileage, on the truck as Considered by these days standards , isnt bad. If moneys tight I would keep it exactly as it is. The swap, while you have a whole lot of parts, Will cost you a Whole lot more then doing Nothing with the truck as is. Plus your new MPG will suck and then the unforseen gremlins,$$$ and grief, that will pop up just wont be worth it. If you had a good income coming in right now I would consider it. But since your laid off, for Now, I would leave well enough alone. IMO, this is No time, to be doing something like this. Your 03 truck as is, works fine as stated. Your time, would be better spent in doing side jobs and making a little Extra bucs on the side then doing a old school engine swap on a 03 Dodge 4.7 pickup with all its modern efficiencies. Thats my honest opinion. mike ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: My Tow Rig...
[Re: Sport440]
#435829
08/12/09 11:01 PM
08/12/09 11:01 PM
70dusterjohn
Deerfield, Ohio
Yeah your probly right.. I'm just sooooooo tired of sitting around doing nothing.. And yes I'm doing side jobs, not a lot but there starting to roll in... Thanks ![](/ubbthreads/images/graemlins/beer.gif)
Re: My Tow Rig...
[Re: Sport440]
#435830
08/13/09 07:50 PM
08/13/09 07:50 PM
Posts: 4,080 Mo.
racerx
Mo.
I wood leave it alone. ![](/ubbthreads/images/graemlins/Twocents.gif)
