Need pictures of Motor plate mounting tabs #435782
08/12/09 03:24 PM
08/12/09 03:24 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
Hey all. I need some pictures of motor plate mounting tabs that you either welded or bolted to the stock frame rails.
DC
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435783
08/12/09 03:50 PM
08/12/09 03:50 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Hope this helps...
Re: Need pictures of Motor plate mounting tabs [Re: 70dusterjohn] #435784
08/12/09 05:13 PM
08/12/09 05:13 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Mine's ugly, but it works.
Re: Need pictures of Motor plate mounting tabs [Re: mopowers] #435785
08/12/09 05:36 PM
08/12/09 05:36 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Best I have for now. I'll try to get more later.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Need pictures of Motor plate mounting tabs [Re: DemonDust] #435786
08/12/09 08:01 PM
08/12/09 08:01 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Not my car but an interesting setup Looks like a 73 Bbody motor mount isolator
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435787
08/12/09 08:02 PM
08/12/09 08:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435788
08/12/09 08:11 PM
08/12/09 08:11 PM
AndyF Offline
AndyF  Offline
Mancini Racing sells a motor plate tab kit that doesn't cost much. You can either bolt them in place or weld them in.
Re: Need pictures of Motor plate mounting tabs [Re: AndyF] #435789
08/12/09 08:28 PM
08/12/09 08:28 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
Many weld them in and many bolt them in. Is there any draw back to bolting the angle brackets in?
DC
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435790
08/12/09 09:01 PM
08/12/09 09:01 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Bondobob probably has an A-body/A-engine plate and mounting tabs that
go together. He has them cut on a water jet.
He made mine custom to use with the 3/8" plate Brian Smith made me.
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435791
08/12/09 09:03 PM
08/12/09 09:03 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The front frame will need a thicker plate welded on, drilled and tapped or weld nuts welded in to bolt the bracket to as the stock frame isn't very thick. so why not just weld on the bracket, just weld it on the back side of the motor plate for easier engine removal.
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435792
08/12/09 09:05 PM
08/12/09 09:05 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
DC
your welding the bracket on a thin sheet of metal
by using a long bolt you are bolted to the whole frame rail
1.39 9.85 - 137 mph
Re: Need pictures of Motor plate mounting tabs [Re: Ari440] #435793
08/12/09 09:34 PM
08/12/09 09:34 PM
rowin4 Offline
rowin4  Offline
DC
Are you saying, use a bolt long enough to go through the total depth of the frame? A Pair of 3/8" bolts would crush a frame rail without welding in some sort of support tubes. Back to welding.
Re: Need pictures of Motor plate mounting tabs [Re: rowin4] #435794
08/12/09 09:39 PM
08/12/09 09:39 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
DC
It wouldn't take much torquing to crush the stock rail...
SDG Motorsports
Re: Need pictures of Motor plate mounting tabs [Re: rowin4] #435795
08/12/09 09:42 PM
08/12/09 09:42 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
DC
I used a flat plate as a washers under the frame rail and tigthened it ,but not to crush the frame rails together
double nutted so it would not come lose
1.39 9.85 - 137 mph
Re: Need pictures of Motor plate mounting tabs [Re: DemonDust] #435796
08/12/09 09:43 PM
08/12/09 09:43 PM
Deerfield, Ohio
Deerfield, Ohio
Before I welded the plates to the frame rail I used a long 3/8 bolt and a 90 bent steel. I use another flat plate on the bottom of the rail also.. I decide to weld the plate on and do away with the bolts cause I didn't want to crush the rail. It also makes it easy to pull the motor out rather than having to hold the top and or the bottom.
Re: Need pictures of Motor plate mounting tabs [Re: 70dusterjohn] #435797
08/12/09 10:12 PM
08/12/09 10:12 PM
AndyF Offline
AndyF  Offline
Rivnuts are a great way to go for this application. Just drill the top side of the frame and install a couple of Rivnuts and you're good to go. There isn't a lot of force being applied by the engine to the mounts. Even if you have 800 ft-lbs of torque that only works out to a few hundred lbs of lift at the mount. A couple of small bolts will hold that just fine.
Re: Need pictures of Motor plate mounting tabs [Re: 70dusterjohn] #435798
08/12/09 10:17 PM
08/12/09 10:17 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Re: Need pictures of Motor plate mounting tabs [Re: dc426] #435799
08/12/09 10:21 PM
08/12/09 10:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A piece of angle iron(2 X 2) welded on the back side
of your engine plate will set works just fine... or
go taller if you need it... but with 2x2 thats alot
of surface area to hold the load. I have a piece of
.090 flat stock welded to my chassis for the plate
for each side... I would also recommend 2 bolts per
side(if the plate moves at all it will bind on the
bolts to eliminate frame flex unlike a single bolt)
also I would use engine limiters with a motor plate
to eliminate any fore and aft movement(a flat plate
in a vertical plane doesnt do much)
Re: Need pictures of Motor plate mounting tabs [Re: MR_P_BODY] #435800
08/12/09 10:51 PM
08/12/09 10:51 PM
Any pics available showing the engine limiter with the motor plate.
Re: Need pictures of Motor plate mounting tabs [Re: ] #435801
08/12/09 11:05 PM
08/12/09 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry no pics but I came off of the engine mount holes
on the block to a tab welded on each side of the
chassis,(1 limiter each side... some use 1 limiter
but I like 2) some use the ears on the trans to the
frame rails
