Re: 360 plug question
[Re: Moparnut426]
#435148
08/11/09 09:13 PM
08/11/09 09:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mr P sugestedthe rn12yc champion plug, what plug are you guys running in your iron headed 360 with 9.0-9.5:1 compression??
just curious I have always had great luck with champion plugs.
Kasey
Or its equivalent.... he's running a 9 now and he's having a issue with his plugs being dark.... but he is also running 10* timing at idle 36 total, I suggested a hotter plug and up his idle timing to 18 and decrease his advance to keep his total timing the same
[Re: MR_P_BODY]
#435149
08/11/09 09:48 PM
08/11/09 09:48 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I think Im going to buy a set of the 12's, and I already have the jets to tinker with while at the track. I know more is in there, I just want to be able to get to it. Thanks Mr P body, and everyone else for helping me with all my stupid little questions. I know u guys have the experiance racing so I like going to the source. Kasey
[Re: Moparnut426]
#435150
08/11/09 10:25 PM
08/11/09 10:25 PM
MR_P_BODY
Kasey
Kasey I believe your biggest issue is the 10* timing at idle... get that up and the engine will come to life still maintain the 36 total.... what dist are you using
[Re: qwkmopardan]
#435153
08/12/09 04:08 AM
08/12/09 04:08 AM
Autolite 3924's...champions are for lawn mowers....
[Re: Moparnut426]
#435155
08/12/09 07:11 AM
08/12/09 07:11 AM
MR_P_BODY
I have an MSD distributor, MSD "mopar performance" box, and themp coil
Change the bushing for the advance and you should be set, some of the guys seem yo like the 11 plug so try them
[Re: Moparnut426]
#435157
08/12/09 07:44 AM
08/12/09 07:44 AM
MR_P_BODY
What bushing should I put in it?
Kasey
I dont recall what color you would need... maybe someone will help... have you checked MSD's website
[Re: mopar dave]
#435160
08/12/09 11:32 PM
08/12/09 11:32 PM
Moparnut426
Well guys, I have to say....
I put the 11 plugs in it, adjusted the MSD distributor with the black bushing, 1 light silver spring, and 1 blue spring. Checked my timming which was DEAD NUTS on 18 initial, and 36 at 3K. Holy Crap!!! This is honestly the first time the car has "come to life" I noticed imediatly it sounded crisper, and as I drove it it had better power, and felt great. I took it a few miles down the road, turned aroun, piss pownded it after a mild launch, and it was fun!! I crused into town and slowed to 25ish before getting into town, then nailed it, banged 2nd and the Mickey ET streets tore loose, and she went all sorts of sideways... KASEY LIKEY!!!
Now I just have to set my pinion angle, and get her to cool better, and we are gonna have some fun.
kasey
[Re: Moparnut426]
#435161
08/12/09 11:47 PM
08/12/09 11:47 PM
MR_P_BODY
kasey
... its magic ... glad its running better, are you still having a heat issue
[Re: Moparnut426]
#435163
08/13/09 09:00 AM
08/13/09 09:00 AM
MR_P_BODY
Yep, still heating, Im sure my tiny lower crank pulley dosnt help, also I Plan on building a chroud for my 16" Bee cool fan.
KAsey
Yeah a street car needs a shroud.... big difference
