Just had a new set or Richmond gears put in my spooled housing using my old bearings by a professional shop here in town. Problem is on one rotatation of ring gear it binds in one spot..one more rotation it will bid in another spot about four teeth down the row...next rotation it will bind in the same spot as first rotation..so on and so on in these same two spots. I think I need to take it back to the installer...what do you think? By binding I mean it just stops from a smooth rotation spinning the yoke by hand..Thanks for any input
