Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: J_BODY] #434253
08/11/09 03:39 AM
08/11/09 03:39 AM
Transbrake in a 11.30 car for what??..my "street" duster with a good built 904.. race clutches,low first gear,full manual valvebody,foot braking 60's in the low 1.40's and pulled my fat [Edited by Moparts - Family Friendly Site - Keep it clean] to 11.0's with a 3.91 suregrip,Moser axles,billet yokes 8 3/4,properly built the 904 and 8 3/4 can take just about anything you throw at them,now if it were a 4-speed car i'd definately go dana..
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? #434254
08/11/09 08:39 AM
08/11/09 08:39 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Since I don't have any first-hand experience racing 904s, I can
only make this observation........In racing applications, the 904
seems to outlive the 8 3/4" by quite a margine.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: S/ST 3040] #434255
08/11/09 08:44 AM
08/11/09 08:44 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Just playin a little devils advocate here. Anyone ever heard of a 904 exploding a drum? 727 doesn't count. Just curious.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: POZEST] #434256
08/11/09 08:47 AM
08/11/09 08:47 AM
S/ST 3040 Offline
S/ST 3040  Offline
Never.........904 drums are substantially smaller in diameter and way less mass.
I weighed both OEM drums, completely empty on my digital scales......
727 high gear drum is 3480.5 grams and 7.496" in diameter
904 high gear drum is 2378 grams and 5.876" in diameter
This example shows the 904 drum is 2.43 lbs. lighter and 1.620" less in diameter.
This picture pretty much tells the story.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: S/ST 3040] #434257
08/11/09 10:12 AM
08/11/09 10:12 AM
S/ST 3040 Offline
S/ST 3040  Offline
You can see one reason why the 904 uses less power.........and why it won't hold as much power.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: S/ST 3040] #434258
08/11/09 10:19 AM
08/11/09 10:19 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
FWIW, my issues with the stock front drum in my 727 were with the snap ring and it not being able to stay in place causing the piston lip seals to tear and the clutches to get burned.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: S/ST 3040] #434259
08/11/09 09:04 PM
08/11/09 09:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...there is a way around that "weight" issue.
I finally "retired" the lightened stock piece last year in favor of a steel aftermarket drum. That drum had 15 years of service.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: J_BODY] #434260
08/12/09 03:49 PM
08/12/09 03:49 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
First things first, the 904 will live just fine as long as you have the steel caged planetaries, it will destroy the aluminum caged one!! You will kill the 8 3/4 it is just a matter of time.
If you want to leave off of a button just put one in, wire it up to the two step and leave with it. You will still have to use your foot but I guarantee that you will learn quickly to lead with your hand and your foot will follow. And even if you are a bit slow coming off of the brake pedal the car WILL drive right through the brakes. I did this quite successfully for years before putting a trans brake in my car and it worked great for me!! It used to be the in thing for stock eliminator until they outlawed it!!
