Transbrake in a 11.30 car w/ a stock 904 & 8/34? #434233
08/10/09 07:40 PM
08/10/09 07:40 PM
Huron, South Dakota, United St...
dustyhof Offline OP
dustyhof  Offline OP
Thinking about a transbrake for the Dart to help with my lights. Right now the car runs 11.30's @ 3000#, with a basically stock 904 and a 8 3/4 with pro gears and a spool. If I keep the launch RPM's down, will it live or will I start breaking stuff? A Dana 60 and a built trans is in the plans, but is a little while down the road. Should I wait, or will it be OK?
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434234
08/10/09 07:46 PM
08/10/09 07:46 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Sell the 8 3/4 and 904 b4 they break. Spend the $$ to build the dana 1st.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434235
08/10/09 07:47 PM
08/10/09 07:47 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What kind of front drum do you have?
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: WILD BILL] #434236
08/10/09 07:53 PM
08/10/09 07:53 PM
dustyhof Offline OP
dustyhof  Offline OP
Pretty sure it's stock. I think the only thing done to this tranny is a low 1st gear set, and a Cheetah manual VB. Dad built the tranny, and he's not around to ask any more.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434237
08/10/09 07:56 PM
08/10/09 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been using a trans brake since I build my car,
the only thing I would suggest would be caps in the
rearend and a back brace... I use the alum center
8 3/4 and a brace... with a 1.19 60'.... your right
at the weight where I would think about changing the
diff(to me its the weight that kills a 8 3/4)... I
use a 727 but I know ALOT of guys using a 904 with
a brake
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: MR_P_BODY] #434238
08/10/09 08:05 PM
08/10/09 08:05 PM
dustyhof Offline OP
dustyhof  Offline OP
I'm planning on changing to a better rear and tranny. Problem is it won't happen until at least after next season. (this stuff all costs money ) Will I break the stuff I have now, or should I just footbrake another season? I really don't want to do a bunch of work on my 8 3/4, when it's coming out anyway. I also don't want to break it before I'm ready to put the good rear in.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434239
08/10/09 08:11 PM
08/10/09 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Continue as you are now.... that way you are pretty
much assured you'd be ok.... JMO
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: MR_P_BODY] #434240
08/10/09 08:13 PM
08/10/09 08:13 PM
dustyhof Offline OP
dustyhof  Offline OP
Will do. Better safe than sorry I guess. Thanks again. You have been a huge help with all my goofy racing ides! Much appreciated!
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434241
08/10/09 08:26 PM
08/10/09 08:26 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Just look at what happened to me when I put in a T brake with a stock front drum.
FWIW I'm now using Mancini's nodular 489 case in my 8 3/4. I don't think it was the brake that killed the OE one though. I think it was a U joint that started it all.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434242
08/10/09 08:31 PM
08/10/09 08:31 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I've been watching this post a little, and I love your Dart. My question is this. If you are having trouble with your lights, work on fixing your reaction time in other ways. Put a shorter tire on the front. That will help with the rollout. Increase the RPM a little. If you don't have one...BUY A PRACTICE TREE. It's the best investment I ever made for my racing ventures.
If you are bracket racing, the tire spin you will receive with the smallish slicks on your Dart would outweigh the lazy lights in my opinion. When you consider the issues with broken parts or spending big bucks for expensive drive train components...why bother. Keep your money in the bank for unseen breakage down the road. Work on fixing the problem, and you will be a happier racer. Good luck.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: WILD BILL] #434243
08/10/09 08:31 PM
08/10/09 08:31 PM
dustyhof Offline OP
dustyhof  Offline OP
OK. You guys talked me out of it. Not going to do it until I get a better rear and trans. I'm tossing around the idea of a glide anyway. No sense in buying 2 transbrakes.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: Tommy D] #434244
08/10/09 08:37 PM
08/10/09 08:37 PM
dustyhof Offline OP
dustyhof  Offline OP
I don't have lazy lights, just inconsistent lights. Just thought a button would make the car a bit more competitive, that's all. Thanks for the compliments on the car, but I'm just trying to be a more competitive racer. I'll spend my money how I like, thank you. Just wanted to know if my parts would hold up, that's all.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434245
08/10/09 09:05 PM
08/10/09 09:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
get a practice tree and all the seat time you can. make sure your car is capable of running the number. then worry about everything else.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: Quicktree] #434246
08/10/09 09:56 PM
08/10/09 09:56 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
71 dart with 360/904/ 8 3/4 going on 3rd year racing...
trans ordinally was stock except transbrake...ran whole year on it...replaced engine..
while changing out 360 to faster engine...i rebuild 904 ...upgraded to 5 disc in front clutch...24 spring kit to replace large spring in front drum piston....and using kelvar bands...
deep sump from summit..and tranzact brake.
dart has run a best of 11.00s in las vegas..
Tony
70 AARCuda Vitamin C
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: dustyhof] #434247
08/10/09 10:56 PM
08/10/09 10:56 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I don't think you need anything fancy in a 904, especially @ 11.30. Mines
going together with almost all stock parts.(both drums, gear sets, shafts)
with an A&A Pro-brake, high-gear spring kit and a deep pan. I will put an
aluminum front drum in it when I free up the cash.
BTW, 904s and 727s valve bodies interchange.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: S/ST 3040] #434248
08/10/09 11:11 PM
08/10/09 11:11 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
If it were me, I'd wait for the new rear...
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: 70dusterjohn] #434249
08/10/09 11:25 PM
08/10/09 11:25 PM
S/ST 3040 Offline
S/ST 3040  Offline
But, it's fun while it lasts.
Post deleted by Defbob [Re: S/ST 3040] #434250
08/10/09 11:30 PM
08/10/09 11:30 PM
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? #434251
08/11/09 12:24 AM
08/11/09 12:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Here's what our old 360 (10.9/low 11) did to our stock 8.75 axles. We lost a set of gears a couple years back too.
....I still had a set of stock spline Dutchman axles that I used in my car so we put those in the Duster with pretty good success......Until the W5 mill got ahold of them. Twisted those bad. That was the reason the car didn't hit the track until late June. It now has a Dr Diff D60 in place.
Re: Transbrake in a 11.30 car w/ a stock 904 & 8/34? [Re: J_BODY] #434252
08/11/09 12:43 AM
08/11/09 12:43 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....and if you want a 904/Tranz Act brake equipped 904 with a Dynamic converter built to take the abuse I just happen to know where one is sitting.
