Electric fan and shroud for 26" radiator ? #433775
08/10/09 11:52 AM
08/10/09 11:52 AM
Jamey Offline OP
Jamey  Offline OP
Ok Guys, I need an electric fan with shroud for a 26" radiator. I've seen some for the 22" rad, but not the larger one. What are you using and or suggest? Thanks Jamey
Re: Electric fan and shroud for 26" radiator ? [Re: Jamey] #433776
08/10/09 01:44 PM
08/10/09 01:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
make your own & it becomes cheaper.
Re: Electric fan and shroud for 26" radiator ? [Re: rebel] #433777
08/11/09 06:12 AM
08/11/09 06:12 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Electric fan and shroud for 26" radiator ? [Re: Kam*Kuda] #433778
08/11/09 07:20 AM
08/11/09 07:20 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
https://board.moparts.org/ubbthreads/show...rue#Post5345747
Check out that link. Works like a champ.
Re: Electric fan and shroud for 26" radiator ? [Re: TheOtherDodge] #433779
08/11/09 10:34 AM
08/11/09 10:34 AM
Jamey Offline OP
Jamey  Offline OP
I was looking at the hhr fan, but after checking last night I don't have enough clearance.
Re: Electric fan and shroud for 26" radiator ? [Re: Jamey] #433780
08/11/09 01:34 PM
08/11/09 01:34 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
I have the hhr fan on my 69 gtx.Works good
Re: Electric fan and shroud for 26" radiator ? [Re: gtx69] #433781
08/11/09 01:42 PM
08/11/09 01:42 PM
NY usa
540challenger Offline
NY usa
It's big money but Spal makes a dual fan set-up.
http://www.spalusa.com/store/main.aspx?p=itemdetail&item=30102130
It is 25.8 inches across
Re: Electric fan and shroud for 26" radiator ? [Re: 540challenger] #433782
08/11/09 03:35 PM
08/11/09 03:35 PM
Jamey Offline OP
Jamey  Offline OP
Ouch, That spall fan is expensive. I just measured the distance between my radiator and water pump pulley. I have less than 3 1/2 inches of clearance to work with, unless I modify my core support.
Re: Electric fan and shroud for 26" radiator ? [Re: Jamey] #433783
08/11/09 06:55 PM
08/11/09 06:55 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
What type of car and what is the distance from the water pump center(little nose that sticks out)that you center the pully on.I do have one on the gtx hhr fan and i did get it to work without any changes to the car.I will post pictures wednesday
Re: Electric fan and shroud for 26" radiator ? [Re: gtx69] #433784
08/12/09 09:36 AM
08/12/09 09:36 AM
Jamey Offline OP
Jamey  Offline OP
The car is a 67 belvedere. My problem is my aluminum radiator was custom made with 1 1/4" cores instead of 1" cores. I was thinking of running a stock shroud with a slimline fan installed in the shroud.
Re: Electric fan and shroud for 26" radiator ? [Re: Jamey] #433785
08/12/09 11:29 AM
08/12/09 11:29 AM
Houston, Texas
Houston, Texas
I had clearance issues with the WP also, but I just offset it from the center.
Re: Electric fan and shroud for 26" radiator ? [Re: TheOtherDodge] #433786
08/12/09 02:51 PM
08/12/09 02:51 PM
Jamey Offline OP
Jamey  Offline OP
How much clearance did you have from your radiator to water pump? I have around 3 1/2"
Re: Electric fan and shroud for 26" radiator ? [Re: Jamey] #433787
08/12/09 03:19 PM
08/12/09 03:19 PM
Houston, Texas
Houston, Texas
When you take off the stock fan off the water pump, the shaft takes up about an inch of space. I had to get a grinder (because apparently it was hardened steel-found out after ruining 2 saw-zall blades) and grind it off. I then had to remove the alt and ac compressor and take the idler pulley and belt off. Then I could squeeze it down there. I have about > < space between the fan motor and water pump pulley, but it all fits nice and looks stock.
BTW, I took the radiator out to mount the fan assembly.
