New 6 speed #433647
08/10/09 11:26 AM
08/10/09 11:26 AM
Ohio
LS-300 Offline OP
LS-300  Offline OP
Ohio
I'm in the process of gathering info on putting a new Hemi and a manual trany into a 68 Barracuda. I have seen that the 6.1 can be had with a 6 sp manual. How different is it from the old 4 sp? How much fabrication would be required to mount it? Having more gears to use may be nice but would it be worth it?
1979 Chrysler 300 1968 Barracuda project
Re: New 6 speed [Re: LS-300] #433648
08/10/09 12:52 PM
08/10/09 12:52 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
The trans itself is HUGE. Would require lots of fabrication and probably hang down prety far...
Re: New 6 speed [Re: Bill MeLater] #433649
08/10/09 03:13 PM
08/10/09 03:13 PM
Ohio
LS-300 Offline OP
LS-300  Offline OP
Ohio
The torsion mount on the drivers side is going to require repair as well as the floor in that area. If I have to replace parts of the floor anyway why not make the adjustment? Is the trany that big? Is it a lot longer than most? Any and all imput is helpful.
Re: New 6 speed [Re: LS-300] #433650
08/10/09 03:14 PM
08/10/09 03:14 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I have a picture of my A833 next to the Tremec T56 viper six speed thats going in my dakota. It's on my home computer and I'm at work so I'll post it later on for you.
But yes, it is huge in comparison.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: New 6 speed [Re: blown340] #433651
08/10/09 03:34 PM
08/10/09 03:34 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Here is an F body T56 if it helps give you a general idea of them at least..
Re: New 6 speed [Re: LS-300] #433652
08/10/09 04:02 PM
08/10/09 04:02 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: New 6 speed [Re: HealthServices] #433653
08/11/09 09:34 PM
08/11/09 09:34 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Pics I saved from another site....Dart/6spd
Re: New 6 speed [Re: rjsjea] #433654
08/11/09 09:35 PM
08/11/09 09:35 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
another....the tunnel was raised a few inches and moved back a oouple as well.
Re: New 6 speed [Re: rjsjea] #433655
08/12/09 09:54 AM
08/12/09 09:54 AM
Ohio
LS-300 Offline OP
LS-300  Offline OP
Ohio
Thanks for the picts. Easy to talk about but better to see. I like the frame ties and how they were used for the new trany mounts.
