JET Extension---- #433398
08/09/09 11:40 PM
08/09/09 11:40 PM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
i have a Barry grant 1050 that needs jet extensions.. has anyone used them and are the modified bowls needed or do the extensions work without changing the bowls ??? i dont mind buying them if i need them but didnt want to if there werent needed...
Re: JET Extension---- [Re: BILLYJAY] #433399
08/09/09 11:43 PM
08/09/09 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The BG that I worked on didnt need bowls just used
the extensions and notched floats
Re: JET Extension---- [Re: BILLYJAY] #433400
08/09/09 11:46 PM
08/09/09 11:46 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
the one I have screws into the jets holes and then you screw the jets on to the extentions
you also need a float to clear the jet extentions
they also have a tube that you push over the jet too
1.39 9.85 - 137 mph
