Small block rocker question #433396
08/09/09 11:25 PM
08/09/09 11:25 PM
MN
dustyswinger Offline OP
MN
I am thinking about building another stroker and was wondering which rocker ratio is the best? In my other motor I have 1.6 and have been happy with them. Which is better for pushrod geometry and durability? I haven't picked out the cam but it will only be in the low 500 range. Thanks Craig
Re: Small block rocker question [Re: dustyswinger] #433397
08/09/09 11:34 PM
08/09/09 11:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 1.5 is easier on longevity but the 1.6 give you
a quicker open... your choice... the 1.6 is closer to
the head and might require more clearancing
