8 3/4 side axle bearing failure???????? #433066
08/09/09 09:33 PM
08/09/09 09:33 PM
Newfoundland
mopar_man Offline OP
Newfoundland
My cuz restored a 70 dart . everything rebuilt or replaced. He rebuilt the 8 3/4 , new seal new bearings etc. Less than 1000 miles and oil is dripping on brake shoes.
Just wondering how the side axle bearing gets lubricated when there is a seal between bearing and oil supply . i always thought the seal housing hada very small hole in it to oil the bearing , but my memory may be deceiving me and that idea maybe from another brand lol .
End play was set up just right and he shouldn't have had any problems .
Any idea what could be the trouble ? he haven't got the axle removed yet so he can't determine if there is some weird fault .
Re: 8 3/4 side axle bearing failure???????? [Re: mopar_man] #433067
08/09/09 09:44 PM
08/09/09 09:44 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Bearings need to be packed with wheel bearing grease .
Re: 8 3/4 side axle bearing failure???????? [Re: Dartcuda] #433068
08/09/09 09:48 PM
08/09/09 09:48 PM
Newfoundland
Newfoundland
thanks for the reply , forgot to mention that but both bearing were packed before installation.
Re: 8 3/4 side axle bearing failure???????? [Re: mopar_man] #433069
08/09/09 10:20 PM
08/09/09 10:20 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Sounds like you possibly damaged the inner seal or it was installed improperly. It must be driven into the stop in the housing and driven in very straight or it WILL leak. Axle bearings are not lubricated from the rear end lube. The only lubrication that they should be gettin gis from the wheel bearing grease that you packed into the bearings much like the front wheel bearings. If the axle lube is getting past the seal it will wash out the bearing lube and shorten the bearing life and get into the brake area.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 8 3/4 side axle bearing failure???????? [Re: mopar_man] #433070
08/09/09 10:33 PM
08/09/09 10:33 PM
Just a bad dream, it'll pass. R&R the seals & try to find a seal driver that goes inside the seal to support the ID as you drive it in, this keeps the spring from popping off & makes for less distorsion of the seal itself & if cant find one & using a flat driver pack the spring cavity w vaseline or grease to keep the spring in place as the seal is being driven in. Use a BFH & start the seal straight w several light strokes then drive it home w as few hits as possible. Wrap the splines w something so they wont cut the seal as you put the axles in thru them. Before the axle is in all the way lube it where it will be contacting the seal ID. EDIT put some sealer on the housing ID where the seal OD will reside when it's driven in, to seal that circumference also. MORE EDIT have the pumpkin out so you can get the axles past the seals then remove whatever you wrapped the splines with then put the gearset back in then the axles the rest of the way in.
Re: 8 3/4 side axle bearing failure???????? [Re: RapidRobert] #433071
08/10/09 03:18 AM
08/10/09 03:18 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Ya did you replace the axle seals in the housing? Did you adjust the axle end play properly?
