Re: crankcase pressure/ blowing up valley pan [Re: emarine01] #432740
08/12/09 09:19 PM
08/12/09 09:19 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The last valley pan that I had pop up was caused by a exhaust cam lobe that didn't want to rase the lifter any more.
Re: crankcase pressure/ blowing up valley pan [Re: mac56] #432741
08/12/09 10:58 PM
08/12/09 10:58 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
I understand that it could be all of the issues mentioned above but I found out first hand it doesn't take a lot to destroy the valley pan. This picture of the valley pan I just removed. Yes that is a hole(crack). This was all due to my breather caps being to close to the valve cover baffle. They seemed ok but they were not. The engine was and still is running great. This has nothing to do with the pinging but swollen valley pan does not necessarily mean big problem.
hmm, my friend i was talking about also noticed the pcv was really really close to the baffle as well. could just be that simple
Re: crankcase pressure/ blowing up valley pan [Re: MR_P_BODY] #432742
08/13/09 01:16 AM
08/13/09 01:16 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
With 2 breathers I'm thinking he has broke some rings
.... pull the breathers and run without them and see
if the valley pan still bows up(push it down first)
Is he running the breathers into the exhaust with the check valves? He may have had them go bad. I had it happen on my car. Street driven and bulged 2 pretty close back to back time frame. Took the breather hoses and went to free air. Been fine ever since. Mr. P Body did tell me in another post on this to check the check valves and the tubes that go into the exhaust to confirm there is no problems there.
Just for terminology, when a person says breathers
I take that to be it is venting to atmosphere and
if its hooked up to the exhaust I call that a evacuation
system and in this case he stated breathers
Mr P. Body
You are correct in that. Just I am used to dealing with customers at work who call something what it is either attached to or not even close to what it is. I just figured a little easier if kinda described was all.
Re: crankcase pressure/ blowing up valley pan [Re: dOc …] #432743
08/13/09 01:57 AM
08/13/09 01:57 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
A Nerf football will simply save the .013 thick junk stock valleypan gasket in the event of excessive crankcase pressure. Takes very little to split them and cause a nasty leak which can ruin a day of racing. A $10 nerf football, [the cheapest thing I bought for the car], can save the $20 cost of a new gasket many times over. I have personaly never split one but have seen it numerous times at the racetrack. The member that has the problem will probably find that this cheap "Band-aid" will save him from having this happen to him again and it won't cause wheel hop or beat up the the car like a pinion snubber. Glad you find it humerous Doc.
Home of the 149mph Nerf Football
Re: crankcase pressure/ blowing up valley pan [Re: qwkmopardan] #432744
08/13/09 03:14 AM
08/13/09 03:14 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
JUST THINK Dan .. if you corrected the issue that causes the ballooning .. your car might run 155 or best-er ! ..... seriously.
Has anyone ever "tested" to see how much crankcase pressure it takes to balloon up a valley pan ? .... say in a completely sealed-up engine.
But any engine I have seen has either two breathers OR one breather and a PCV ....OR a single or dual evac system.
It would take some severe(and I mean SEVERE) blowby to do as you suggest. Either bad rings, broken ring lands or a hole in piston(s).
But in the end .. you will butter-your-bread as you see fit.
Re: crankcase pressure/ blowing up valley pan [Re: aarcuda] #432745
08/13/09 05:57 AM
08/13/09 05:57 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
It really was that simple for me. The breathers seemed ok when I put them in but there was enough vertical movement that they could work them selves down to the baffle. I also don't understand why someone would think normal crank case pressure without anything wrong couldn't swell .013 tin. It will push out seals.
Re: crankcase pressure/ blowing up valley pan [Re: mac56] #432746
08/13/09 07:13 AM
08/13/09 07:13 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The key phrase is "normal crankcase pressure". The force required is beyond "normal" and indicates a problem with ring seal. Many times the engines run well enough for the owners. Some still ascribe to "lose is fast". But the truth is ANY pressure in the crankcase is the result of power escaping past the rings or gaskets. An engine that pushes out gaskets and has pressure fed leaks all over is not a good running engine. Just might be "good enough" for some owners/racers.
Re: crankcase pressure/ blowing up valley pan [Re: moper] #432747
08/13/09 07:59 AM
08/13/09 07:59 AM
NJ
440challenger Offline OP
NJ
I'll be getting the specs for the motor today.
He had a shop build it for him.
I think the breathers too close to the baffles could indeed be the problem,there is virtually no room under them. But that doesn't fix the timing issue.
The balancer, he cant read the name of it with it on the car but its black with a red anodized center section. Will post back with specs. Thank you guys
Re: crankcase pressure/ blowing up valley pan [Re: MR_P_BODY] #432748
08/13/09 08:54 AM
08/13/09 08:54 AM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
The original post says no evac, just breathers.. I had the same problem with my 440. Kept blowing valve cover and oil pan gaskets. Put in a evac system and the problem went away.
Tell your friend to do the minimal evac (breathers/header collector) or may need a pump..
RS23L7 4-Speed
Re: crankcase pressure/ blowing up valley pan [Re: dOc …] #432749
08/13/09 10:04 AM
08/13/09 10:04 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I think it would be hard to find a 449 c.i. 915 production headed BBM at 2450# with a single carb and a relativly sm solid lifter cam [.560 lift],that will go faster than 149mph. I must mention I built this motor for a street car that I no longer own, so I stuck it in the racecar. 155mph would be 8.60 range and that would be dificult with any production cyl head N/A. With the proper evac system, ring pack and cyl wall finish there may never be a problem. But I have seen many good running strong BBM motors push the pan up and split it and still run for years. Seen shop towels or pig mat packed between intake and pan to absorb the oil. Street cars would be even more prone to crankcase presure problems as pan evacs don't work with muffs. Indy and Koffels make there valley covers from material 10X thicker, [Koffels] and 20X thicker, Indy. Both obviously were addressing the valley pan issues when they designed the valley covers for there heads. The stock valley pans are weaker than you think.
Re: crankcase pressure/ blowing up valley pan [Re: qwkmopardan] #432750
08/13/09 07:11 PM
08/13/09 07:11 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Well I had to measure the installed clearance from my breather nipple to the baffle and found less than a 1/16, I thru a vac gauge on it and get 2.5" @ 1200 rpm, pull it back so its almost coming out of the rubber and get 3" so there is definitely something to it, I will grind another 1/16 off the nipple for now and hunt a shorter breather, who would of thought and we weren't having any back pressure problems but like having more
Re: crankcase pressure/ blowing up valley pan [Re: emarine01] #432751
08/13/09 07:58 PM
08/13/09 07:58 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Done the same thing plus gave the baffle a little tweak.
Re: crankcase pressure/ blowing up valley pan [Re: mac56] #432752
08/13/09 08:48 PM
08/13/09 08:48 PM
NJ
NJ
Ok its a stroker 440 . 499ci
Powerforce 90013 balancer???
SRP psitons at 10.5.1 comp.
eddy heads.
crane gold roller rockers 1.5
Crane hydro roller.689541
Cam specs here:
http://www.summitracing.com/parts/CRN-689541?part=CRN-689541&autoview=sku
MSD pro billet dizzy with 6al
QUick fuel 850 w/ eddy rpm intake
