Are Phoenix slicks capable of holding air w/o tubes?
#432640
08/09/09 03:47 PM
08/09/09 03:47 PM
Posts: 699 Manassas, VA USA
Scamp451
Manassas, VA USA
First set of slicks I ever owned were a pair of used Hoosier mounted on new rims. Both held air with no problems at all. I replaced the Hoosiers with a paor of Pheonix, and they would lose at least pound between rounds. My friend mounted them on his rims and they would not hold air either. Went to a set of small E/T streets on the same rims, they would hold air at least a week. Went to a set of M/T slicks and they did about the same. I have another set of Phoenix now and they are ust as bad as the other pair. Anyone else have the same problem with Phoenix slicks? Maybe I will caulk the beads and fill em't w/ fix a flat! ![](/ubbthreads/images/graemlins/laugh2.gif) (kidding). I did not screw the beads yet, not sure if they halps or not. I guess if I have to run tubes, I will.
Re: Are Phoenix slicks capable of holding air w/o tubes?
[Re: Scamp451]
#432641
08/09/09 06:10 PM
08/09/09 06:10 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We've always used tubes,and have been Firestone/Phoenix users for years.I'd go ahead an install the tubes,with good rotation and proper inflation while stored(20 lbs) the tires will hook great and will last a long time.
[Re: 440Jim]
#432645
08/09/09 07:59 PM
08/09/09 07:59 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I coated the inside of my M/Ts with Dawn 3 nights in a row then had them mounted and they dont hold air a week.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#432646
08/09/09 08:12 PM
08/09/09 08:12 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Tubes and screws...Tubes and screws... Tubes and screws!!!
The little old lady from Pasadena is back!
[Re: Barnstorm]
#432647
08/09/09 08:22 PM
08/09/09 08:22 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Screws and no tubes here, Dawn dish soap, mount the next day, never any leaks with Phoenix, M/T or Hoosier.
[Re: Butch]
#432651
08/09/09 11:52 PM
08/09/09 11:52 PM
ProSport
Akron, Ohio
Bob you don't keep a set of tires long enough for them to leak.
I've had this set for 2 seasons. ![](/ubbthreads/images/graemlins/tonguue.gif)
