Tractor pull in NC
#431961
08/08/09 11:16 PM
08/08/09 11:16 PM
Posts: 3,695 nc
emarine01
nc
NTPA held a event in Newport NC this week end, Good turn out, not enough parking or seats, lots of tractors and pulling trucks, one mopar mod truck out of West VA won , He was the only mopar out of the whole show except for the blown hemis, lots of chebbies & fords, cool show all in all for the first time in Newport, they had said they were not expecting that big a turnout & next year they will be better prepared ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Tractor pull in NC
[Re: emarine01]
#431965
08/09/09 03:43 PM
08/09/09 03:43 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
Was the truck green/yellow called "to the X-treme"???? real low? Dakota body i think. If its him he does real well everywhere he goes.... to bad its a bowtie under the hood ![](/ubbthreads/images/graemlins/frown.gif) We've run 636ci b1-TS engine at one pull found out a small problem. Were taking it out. gonna put it on the dyno get the injection system working right and be ready for the 21st. Had to put a new trans in it too. Hopefully we can keep up on the power tracks now ![](/ubbthreads/images/graemlins/smile.gif)
[Re: emarine01]
#431968
08/09/09 04:21 PM
08/09/09 04:21 PM
Diablo
Quebec, Canada
is it the dodge truck that was in the first few pics? http://www.truckpullingunleashed.com/id33.htmlThere are alot of dodge trucks on the big circuit that use bowtie engines. Dixie chopper is another one of them. There are two dodge trucks called Dodge N Bullets. They both run 650ci with the 500ci prostock hemi stuff ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Diablo]
#431972
08/09/09 08:39 PM
08/09/09 08:39 PM
Posts: 976 ontario canada
mac56
ontario canada
Doug are you still running an automatic behind the new engine?
[Re: Diablo]
#431975
08/10/09 05:57 AM
08/10/09 05:57 AM
mac56
ontario canada
Ya i had a modded 727 built by fireball trans in ontario and a special torque made.
I dont see having a problem but maybe. it seems with running LOW LOW gears in the differentials (688), running the trans in 3rd, not shifting and keping the rev's down (7000-7500) everything stays together just fine
I didn't realize you could get enough gear to run high gear in the transmission. As asked above I would assume you must also have some reduction in the transfer case?
