Front Trans seal
#431265
08/08/09 09:48 AM
08/08/09 09:48 AM
Posts: 1,560 Michigan
Kiddart
Brand new trans just out of the box. front seal for converter is leaking!! what did I do wrong or is this just bad luck??? its a 904 from a very repitable shop will it go away???
Drowning in trans fluid Kiddart
Thank you Kiddart
Re: Front Trans seal
[Re: Kiddart]
#431266
08/08/09 10:07 AM
08/08/09 10:07 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
if its the front seal it wont go away are you sure it not venting fluid from the vent for some reason maybe overfilled
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#431267
08/08/09 10:13 AM
08/08/09 10:13 AM
Kiddart
no its not overfilled i an about 1/2 pint short because I thought the same thing. I just hate pulling it all apart for this. this is the only leak on the car and I am afraid to take it to the strip and drop anything on the track.
Thank you Kiddart
[Re: 440Jim]
#431269
08/08/09 10:22 AM
08/08/09 10:22 AM
Kiddart
Converter is new What would be wrong with flex plate?? The spring could have come off thats true. I put lube on the shaft of the converter as i always do also on the pilot to the crank.
This is all good stuff. Thanks
Thank you Kiddart
