Re: Cleaning the inside of the valve cover breather?
[Re: SeventySatellite]
#430412
08/06/09 11:37 PM
08/06/09 11:37 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I've soaked them in gasoline for a couple days that seems to help ![](/ubbthreads/images/graemlins/thumbs.gif) (or in the solvent tank) Then just rinse them out afterwards..
#430416
08/07/09 11:53 PM
08/07/09 11:53 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I will be removing the old paint and giving it a fresh coat of new. Should the black be a gloss or semi-gloss?
Semi gloss will sulfice,....usually I tape of the the openings, and glassbead the surface, then soak them in a container of laquer thinner, breaks up the oil and gunk pretty good, then blow them out with compressed air, prep with etch primer paint with semi gloss black, or 30% flattened black acrlic enamel Centari (Dupont)
