anyone use these TAYLOR plug boots before? #428417
08/04/09 12:17 PM
08/04/09 12:17 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Here's a pic from Summit.
http://www.summitracing.com/parts/TAY-2522/?image=large
The ones in question are the ones on the LEFT. They are silicon coated.
Question I have is can they touch the header? I've used the ones on the right before, but could not get any locally, but I can get the ones on the left.
I don't want them to melt all over my tti headers
codfish
Re: anyone use these TAYLOR plug boots before? [Re: codfish] #428418
08/04/09 01:48 PM
08/04/09 01:48 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sure, they can touch the header and they will survive, and will not melt.
In that scenario, the plug boot on the wire STILL MELTS, only it melts inside the sleeve where you can't see it.
I've seen it happen about a half dozen times now
Re: anyone use these TAYLOR plug boots before? [Re: ZIPPY] #428419
08/04/09 02:17 PM
08/04/09 02:17 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Do what ever you can to keep the plug boot from touching the header
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: anyone use these TAYLOR plug boots before? [Re: BloFish] #428420
08/04/09 02:35 PM
08/04/09 02:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kid has the ones on the right on a few of his Taylor wire.They have been on for 3 years and he has 2 1/8 tubes.No problems with the ends ever.His gets street driven and raced so it gets a ton of miles.My 440 just has Taylor wires and they are 9 years old at least with 2 inch TTIs street and strip.No problems.Rocky
Chrysler Firepower
Re: anyone use these TAYLOR plug boots before? [Re: therocks] #428421
08/04/09 09:55 PM
08/04/09 09:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Haven't used the ones on the left. Have the woven ones on the right on a 454, cast iron manifolds, been on there for years and as much heat as the manifolds radiate, zero problems; but they don't touch the manifolds. A buddy of mine has the woven style on his 454 and they have burn spots where his touch his headers.
Not really the answer you're looking for, just passing on my experience.
