Page 8 of 28 1 2 6 7 8 9 10 27 28
Re: My 63 Dodge 330 Project: #428337
05/19/11 10:20 PM
05/19/11 10:20 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Put the radiator in and used these nifty Gates Powergrip hose clamps that are heat shrink to fit!
I'm tired of scraping my knuckles on the old worm-gear or corbin style clamps!
It is looking good. As far as those corbin clamps go, I cannot stand them
Re: My 63 Dodge 330 Project: [Re: DusterKrazy] #428338
05/28/11 07:46 PM
05/28/11 07:46 PM
Anonymous OP
Anonymous OP
Into the great outdoors.
Some of the first overall shots of the car in quite a while since I let it out of the cage today.
I'm probably going to put some lowering blocks on the rear since the SS spring have it sitting WAY high!
Re: My 63 Dodge 330 Project: #428339
05/28/11 07:49 PM
05/28/11 07:49 PM
Anonymous OP
Anonymous OP
Down da side.
Re: My 63 Dodge 330 Project: #428340
05/28/11 07:53 PM
05/28/11 07:53 PM
Anonymous OP
Anonymous OP
Need to get the 15x8 steelies and some tires put on the back.
Re: My 63 Dodge 330 Project: #428341
05/28/11 07:57 PM
05/28/11 07:57 PM
Anonymous OP
Anonymous OP
udder side.
Re: My 63 Dodge 330 Project: #428342
05/28/11 08:01 PM
05/28/11 08:01 PM
Anonymous OP
Anonymous OP
Full Frontal.
Re: My 63 Dodge 330 Project: #428343
05/29/11 12:00 AM
05/29/11 12:00 AM
Anonymous OP
Anonymous OP
I think the stance looks really good the way it is.
Re: My 63 Dodge 330 Project: [Re: ] #428344
05/29/11 12:07 AM
05/29/11 12:07 AM
Anonymous OP
Anonymous OP
I'll see how it looks after I get the taller and wider tires and rims out back. I'm not a huge fan of the stinkbug stance!
The first picture on the first post was with the stock /6 springs and I liked that look a whole lot better.
Re: My 63 Dodge 330 Project: #428345
05/29/11 12:15 AM
05/29/11 12:15 AM
Anonymous OP
Anonymous OP
I don't like a big rake on cars either. Put your other rear tires on and put the car on a level surface and then show us. Pics with the car sitting on a sloped drive way is deceiving. The car is looking great though.
Re: My 63 Dodge 330 Project: [Re: ] #428346
08/02/11 03:05 PM
08/02/11 03:05 PM
Anonymous OP
Anonymous OP
Not accomplishing much because of the heat! Supposed to be 113* here today!
Re: My 63 Dodge 330 Project: #428347
08/02/11 03:08 PM
08/02/11 03:08 PM
Anonymous OP
Anonymous OP
*smirk*
Re: My 63 Dodge 330 Project: #428348
08/02/11 03:55 PM
08/02/11 03:55 PM
Anonymous OP
Anonymous OP
Re: My 63 Dodge 330 Project: #428349
10/16/11 09:01 PM
10/16/11 09:01 PM
Anonymous OP
Anonymous OP
It LIVES!
Fired it for the first time and it sounds awesome!
Instant throttle response and open headers sound bitchin'!
Re: My 63 Dodge 330 Project: #428350
10/16/11 09:47 PM
10/16/11 09:47 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: My 63 Dodge 330 Project: [Re: Neil] #428351
10/30/11 11:31 PM
10/30/11 11:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That is looking great ! You have really put alot of hard work into it and I am sure it will be worth it when we see it done. And you have the right valve cover stickers on it. Ron
Re: My 63 Dodge 330 Project: #428352
10/31/11 02:46 AM
10/31/11 02:46 AM
AZ
d4rt Offline
d4rt  Offline
AZ
It's been a long time since I posted on here! Car is looking good!
Re: My 63 Dodge 330 Project: [Re: d4rt] #428353
10/31/11 09:32 PM
10/31/11 09:32 PM
Anonymous OP
Anonymous OP
Thanks guys!
This summer has been really rough as I was employed off and on and really didn't want to spend money until I saw how the job situation shook out.
The car was so close I could taste it!
I did get the transmission cooler done, lubed up my rearend and and cleaned up some more underhood.
At least it's running before winter and I can work on small stuff to get it on the road by spring.
I realized the other day about the only thing left of the car I originally bought was the basic body shell, dash trunk lid and passenger door!
Re: My 63 Dodge 330 Project: #428354
02/17/12 09:29 PM
02/17/12 09:29 PM
Anonymous OP
Anonymous OP
Crossmember shot for someone to reference.
Re: My 63 Dodge 330 Project: #428355
02/18/12 03:13 PM
02/18/12 03:13 PM
Rochester, NY
Red63440 Offline
Red63440  Offline
Rochester, NY
Looks really great and I have been following your build fairly closely. What did you use to re-dye your kick panels and other interior parts?
68 Barracuda Fastback
Re: My 63 Dodge 330 Project: [Re: Red63440] #428356
02/18/12 10:47 PM
02/18/12 10:47 PM
Anonymous OP
Anonymous OP
Duplicolor vinyl and fabric.
I also used their adhesion promoter.
I start out by thoroughly cleaning the parts with wax and grease remover and then liberally apply the adhesion promotor.
I tried really hard to scratch some off the back of the kick panels and couldn't do it! I was really impressed with how well the stuff works.
