Hi,
I just rebuilt the 727 for my 440 Challenger, installed new bands, clutches, rear billet servo etc and a Trans-Go TF-2. The trans and valve body are both 1977 parts. I never had this VB installed in the car before so it might be faulty, although I dind't find anything wrong with it while installing the TF-2.
I adjusted the kickdown-linkage correctly, have WOT 2-3-upshift at 75mph with 3.23 gears. The WOT 1-2-upshift is at a low 35mph and it doesn't seem to use the PTK (which definitely is installed).
Low throttle upshifts are at 15 and 25mph which seem to be a bit on the high side but I can live with that.
What can cause this early 1-2 upshift while the other is ok? Car feels slow at low speeds, not using PTK adds to this
This was the first time I installed a TF-2. I found the instructions quite confusing here and there. But I got older instrucions from another guy which cleared up something. I hope but cannot guarantee that I did everything correctly.
Jens
