Trans line pressure
#427657
08/03/09 08:10 PM
08/03/09 08:10 PM
dartman366
Mt. Vernon, Ohio
Why do transbrake vb's have such a variation in line pressure, my TA has 125# and I have heard griner's and some others have as much as 185#,, my question is, could I up the pressure on mine and what effect would it have if I did, also is the line pressure have an effect on the clutch clamping of the notoriously small high gear clutch and maybe help it live longer by clamping tighter. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Re: Trans line pressure
[Re: dartman366]
#427660
08/03/09 09:16 PM
08/03/09 09:16 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Bill............Rick Allison makes an aluminum high gear drum for the 904 with a much bigger piston. Should hold the car better while on the trans-brake, if you have a big chip in the 2-step. ![](/ubbthreads/images/graemlins/smoke.gif) That's what is going in mine.
[Re: Dunnuck Racing]
#427665
08/03/09 10:43 PM
08/03/09 10:43 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Not to hijack Bill's post but all this is making me wonder what mine is. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
If I can get my idle line pressure up to around 180 would that enable me to set the brake at idle and have it release as quickly as it does when I set the brake at 2000 RPM?
