Rim Screws or Not?
#427557
08/03/09 06:13 PM
08/03/09 06:13 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
I had my new tires mounted and found out when we went to balance them that they where bent. Since I have to buy new rims now not sure if I need to screw the slicks to the rims. The tire size is 30x11.50 Goodyears and the engine makes about 600hp. I have never ran screws before, but they where on old rims and not sure if I need to drill my new rims or not? How many of you guys run screws?
Switched to the dark side...
Re: Rim Screws or Not?
[Re: MR_P_BODY]
#427559
08/03/09 06:36 PM
08/03/09 06:36 PM
Posts: 4,703 On the parachute mount
n20mstr
DragRadials here , NO screws, been 1.24 60 foots Yes they have moved a lot, one is almost one full rotation now, never vibrated etc, Prob moved 1 inch or less each pass
If you research it you will find 99.9% of Stock and Super Stock cars DO NOT run wheel screws or tubes
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#427560
08/03/09 07:01 PM
08/03/09 07:01 PM
Quicktree
do you think a tire moving 1" on a pass will effect RT? and do you think it will move the exact amount every pass?
[Re: rockerbob]
#427562
08/03/09 07:08 PM
08/03/09 07:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think this comes up about once a month.... do a search.... makes a difference on the tire pressure
Hello Mr P Body. Could you elaborate please. I just added wheel screws to my car. I spun a tube & it punctured. Did not reinstall tube. Suprisingly PSI is constant. Is that what you mean?
On a low pressure tire like my set up 7 psi I can spin the tire on the rim real easy... unlike a car that uses a higher pressure... higher pressure you have more force holding the tire to the rim.... I screw the rims and use tubes ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rockerbob]
#427571
08/03/09 11:11 PM
08/03/09 11:11 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Srew it and tube it for bias plys. Radials I ll defer.
The little old lady from Pasadena is back!
[Re: topside]
#427573
08/04/09 07:54 AM
08/04/09 07:54 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Bias ply tires I always had screws and tubes in them. I ran rubes b/c I still drove it on the street and didn't like having to air up the tires every other day.
I run radials now w/ screws. CHIP
[Re: JSR1485]
#427574
08/04/09 09:05 AM
08/04/09 09:05 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
We never screw the tires on the Stockers. 9" @ 10.5psi stick car that hammers the tires initially. Even on Hemis cars, no screws but with a radial @ 16psi.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#427575
08/04/09 09:12 AM
08/04/09 09:12 AM
Posts: 34,976 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
No screws, tires have never moved
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: sixpackbee]
#427576
08/04/09 09:16 AM
08/04/09 09:16 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
'68 Cuda runs 11s 26x10 MT on 15x8 wheels 17psi no screws
'71 Cuda runs mid 9s 14x32 GY on 15x12 wheels 7.5psi 4 screws on the inside, none on the outside.
Rear Engine Dragster runs high 7s 16x33 on 15x15 wheels no screws 5.5psi
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
