Re: Whats the trick to bending steel fuel/trans lines?
[Re: 65Valiant]
#426996
08/03/09 08:26 AM
08/03/09 08:26 AM
Posts: 15,487 Florida
scratchnfotraction
a "ridged" (brand name) cast alum tubing bender 1/2"-3/8-5/16 tubes in one bender works best PVC pipes and pullys will work but the bender will make nice tight bends with no kinks
[Re: 65Valiant]
#426998
08/03/09 10:40 AM
08/03/09 10:40 AM
Posts: 25 Delaware
crazy4carz
Delaware
Ill try that on another test piece, yet I need to make some tight bends
anyone wanna let me borrow a high end bender?
Where are you? I have several benders as well as nice double flare equipment.
[Re: 65Valiant]
#427004
08/03/09 03:21 PM
08/03/09 03:21 PM
RapidRobert
If the radius you are after is making it kink I'd (as said) fill it w something & (carefully) heat it as you bend it w the bender that supports it on 3 sides. grab a helper.
