Raise the vehicle and use jack-stands. You need to back off the torsion bar adjuster bolt located in each LCA.
There can be retention clips in the torsion bar mount ends, that need to be removed with a screw driver.
Sometimes, torsion bars can be removed easily, but often times they are stuck in place from years of service.
There are clamp-tools that can be fabricated or purchased, which you clamp onto the torsion bar and hammer against (the removal tool) to dislodge the T-Bar from the mount.
![](http://www.arengineering.com/articles/Image18.jpg)
Here is a good link about T-Bars and scroll down for tips on removal:
http://www.arengineering.com/articles/tbartango.html
