Hmmmm. How old / New is the distributor and in what condition is it? Has it been checked on a machine?
When you installed the cam in the engine, did you use a Degree-Wheel to verify the installation was correct?
Your Cam-timing could be advanced or retarded irrespective of your crankshaft damper timing mark.
New Camshafts can actually be off a bit, even though you lined up the timing marks on the cam / crank timing-chain gears correctly. The Only positive way to know for sure, is to use a degree wheel to check / verify.
Also, some engine builders intentionally install the cam "advanced" or "retarded" to slightly adjust the cam timing events.
Furthermore, do you "really" need the vacuum advance? I capped off the vacuum-advance on the distributors in my 71 Charger and '79 Jeep CJ-5 (AMC 304 V8) engines, 8-or-so years ago.
I re-curved the distributors a bit and rely on Total-Advance (around 32 to 38-degrees) checked at 3,000 to 3,500 RPM with a timing light. I don't even worry about what the "Initial" advance is, so long as it starts.
