Re: Distributors / Info needed.
[Re: 70mopar]
#424666
07/31/09 01:40 PM
07/31/09 01:40 PM
Posts: 52 Oklahoma, Piedmont
staightarrow
Oklahoma, Piedmont
I don't know if they are big block or not but as far as value... if they are rebuildable then probably no more than $15 at most. I just bought a rebuilt dist for my 440 at pepboys for around $40 including cap and rotor. Good luck
At least it not a crack habit.
[Re: 70mopar]
#424667
07/31/09 02:56 PM
07/31/09 02:56 PM
RapidRobert
All I can offer: The direction the vac adv flat arm curves around(on the inside)of the dist is the direction of rotation(as you know CCW for BB) which only leaves the 2 different shaft lengths between a (B) and a (RB). Sb's-CW & all the same length.
[Re: 70mopar]
#424670
08/01/09 06:58 PM
08/01/09 06:58 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Also has B7 4968 S stamped on carb.
71 - B,J,R,W,P,D,C 440 Auto. 4bbl Carter 4968S
B7 is probably B1 - Feb 71
[Re: 70mopar]
#424671
08/01/09 07:16 PM
08/01/09 07:16 PM
Snoopy
I also have Part # 343822 with 41 9 above that. I believe this is a 440 & 440 6 Pack Auto Distributor.? Also worth $5.00 ..?
3438221 - 70 P,D,C,Y 440 all transmissions.
3438224 - 70 B,J,R,W,P,D,C, w/H/Perf., 440 w/l-4Bbl.Carb.
