Adding Frame Connectors #424627
07/31/09 09:36 AM
07/31/09 09:36 AM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
Hi,
I have my car on a rotisserie and want to add frame connectors. The car is connected at the bumper mounts. If I flip the car over to weld them will the body have the correct loading?
Re: Adding Frame Connectors [Re: whitemtnelf] #424628
07/31/09 10:16 AM
07/31/09 10:16 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
It'll be easy, but you won't be happy
Re: Adding Frame Connectors [Re: whitemtnelf] #424629
07/31/09 10:21 AM
07/31/09 10:21 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
No it will not. If your making your own with 2X3 dom you can fit them by opening the rear rails, and cutting the floor to slide the tubes in place but do not weld them in until the car is loaded (I.E. Drive train in,) and resting on the suspension.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Adding Frame Connectors [Re: Noblewk] #424630
07/31/09 10:42 AM
07/31/09 10:42 AM
New Hampshire
W
W
New Hampshire
I'd like to get them welded in before priming and coating (truck bed liner) the underside. I was hoping to find a way to properly load the car without taking it off the rotisserie. But it looks like I'll have to take it off and install the engine and rear end. I've gotten vertical welding down, but I'm not looking forward to over head welding
Re: Adding Frame Connectors [Re: whitemtnelf] #424631
07/31/09 12:26 PM
07/31/09 12:26 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Talk to XV Motorsports or US Car Tool and see what they say. US Car Tool shows them being installed on a car that is on a rotisserie.
Re: Adding Frame Connectors [Re: whitemtnelf] #424632
07/31/09 12:28 PM
07/31/09 12:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Overhead welding is no big deal. Back off the heat(wire feed)and speed up your feed (your actual speed - not the wire feed). This keeps the molten metal from forming a bead and falling in your eye!! If you aren't already using it and have the option, use straight CO2 - not a mix. Some will claim they can do overhead with a mix but there are magicians on every subject you can name on here. The straight CO2 is WAY better for overhead welding. I normally use a mix but if it were me I would rent a small bottle JUST for this job - that's how strongly I feel about it.
Re: Adding Frame Connectors [Re: Stanton] #424633
08/01/09 09:41 PM
08/01/09 09:41 PM
New Hampshire
W
W
New Hampshire
I'll send some emails to the vendors and update the post with the responses. Thanks for all of your feedback.
Re: Adding Frame Connectors [Re: Stanton] #424634
08/02/09 06:58 AM
08/02/09 06:58 AM
JOPLIN MO 64804
RBDART1 Offline
RBDART1  Offline
JOPLIN MO 64804
You could build and fit them,bolt them in loosely till the car is loaded, then weld them....
Re: Adding Frame Connectors [Re: RBDART1] #424635
08/02/09 11:18 AM
08/02/09 11:18 AM
Tampa, FL
Garranimal Offline
Garranimal  Offline
Tampa, FL
Not to hi-jack this thread but i was about to post a similar question. I am about to install frame connectors but i have the entire front suspension and K-frame out of the car. the car is currently supported on the frame rails front and rear, the doors and trunk are shutting perfectly......would it be a mistake to put the connectors in at this point?
Re: Adding Frame Connectors [Re: whitemtnelf] #424636
08/13/09 12:45 PM
08/13/09 12:45 PM
Northern Territory, Australia
Z
Zapp Offline
Zapp  Offline
Z
Did you get advice back from the Manufacturer, I have a set of connectors and my car too is on Rotiserrie, I know US Car tool's Web site has photos of cars being fitted with Connectors while on a Rotisserie but some here advise against it. I am yet to hear real experiences of things going wrong fitting them in this way but some seem to suggest it will not work out
Re: Adding Frame Connectors [Re: Zapp] #424637
08/13/09 01:24 PM
08/13/09 01:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I spoke to John at US Car Tool about putting mine on while the car was on the rotisserie and he said it's fine.
If you have a super rusty car or a well abused ex-race car with a lot of body flex then it might not be a good idea. My dart was a clean low mileage car that seemed very tight so I went ahead and had mine welded on with the car placed in the vertical position on the rotisserie.
Re: Adding Frame Connectors [Re: Neil] #424638
08/13/09 03:37 PM
08/13/09 03:37 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
Unless you just got that body from Dynacorn, it's probably pretty good at yoga... If you don't want to weld over your head just talk nice to an exhaust shop and have them do it.
-1967 Belvedere II 440/4speed
Re: Adding Frame Connectors [Re: Neil] #424639
08/13/09 06:57 PM
08/13/09 06:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've have installed them on a rotissiere when the car is a bare shell on it's side and the car came out fine. Everything fit. Get way better welds that way too.
