Fuel system setup questions #424222
07/30/09 06:42 PM
07/30/09 06:42 PM
Imlay City, MI
DTT Offline OP
super gas
DTT  Offline OP
super gas
Imlay City, MI
Im in the process of doing my fuel system in my pickup. Its a pro street style vehicle. Im running -8 line for my feed. I have a fuel cell with a sump. My questions are:
1) The cell I have has foam, can I pull it out and still perfrom well on the street? What are the advantages to running it in a mostly street driven vehicle?
2) My return, should it be one size smaller or bigger than my feed? I have heard reccomendations for doin it both ways.
3) I have seen a lot of vehicles that have the return and/or the vent lines coming out of the cell ran in a coil configuration. Whats the reasoning for this?
4) Does anyone make a reducer that is also a bulkhead? Meaning I can go from -6 to -8 but doing it in a bulkhead through my bed floor.
Thanks a lot. Any other help is appreciated.
1978 Pro Street D100 1936 Dodge truck (Hot rod) 1957 Plymouth Plaza 1962 Chrysler 300 1964 Dodge 440 1995 Jeep Grand Cherokee 1971 Big Block Demon (Dads)
Re: Fuel system setup questions [Re: DTT] #424223
07/30/09 06:54 PM
07/30/09 06:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
what pump and regulator?
Re: Fuel system setup questions [Re: DTT] #424224
07/30/09 07:07 PM
07/30/09 07:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Foam is there to control slosh, you have a sump
but dont have any baffles.... it MIGHT slosh enough
to suck air in a low fuel condition. If you go with
a larger return line(larger than the supply) you know
you wont ever have a pressure build up in the return
causing the regulator to act goofy. I'm not sure about
the bulkhead fitting. The coil of line is for expansion
in the tank, it will break a suction if one were to
develop
Re: Fuel system setup questions [Re: sixpackgut] #424225
07/30/09 09:04 PM
07/30/09 09:04 PM
Imlay City, MI
DTT Offline OP
super gas
DTT  Offline OP
super gas
Imlay City, MI
Mallory 140 pump. Mallory return style regulator.
Re: Fuel system setup questions [Re: DTT] #424226
07/30/09 10:44 PM
07/30/09 10:44 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i don't see any reason to coil the return line. the reason for coiling the vent line is to prevent fuel from sloshing out the vent. as mentioned they recommend using a return line one size larger that the feed for the reason stated.
Re: Fuel system setup questions [Re: DTT] #424227
07/30/09 11:17 PM
07/30/09 11:17 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
I'm using the same, I run # 8 feed to the carb and 3/8 steel return w no issues
Re: Fuel system setup questions [Re: RussW] #424228
07/31/09 02:00 AM
07/31/09 02:00 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
You can get a -8 an female to -6 an male reducer and then screw it onto a bulkhead fitting. But I doubt you can get it as one fitting. And here is a second way that is more compact. In stead of a Bulkhead fitting you can screw the reducer onto a -8 Male X -8 Male fitting. But it has to be tight to make it seal. So you would have to adjust the clearance or tightness on the sheetmetal that is passes through by adding washers or sanding the bottom of the reducer fitting as I already have on this one. It would not hurt if the whole thing was slightly loose on the sheetmetal as long as you backed it with a wrench when you tightened other fittings/lines onto it. Which you should anyways.
Ron.
SRT DEMON ONE SEAT
Re: Fuel system setup questions [Re: Ron Silva] #424229
07/31/09 02:01 AM
07/31/09 02:01 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
the two fittings together
SRT DEMON ONE SEAT
Re: Fuel system setup questions [Re: DTT] #424230
07/31/09 12:38 PM
07/31/09 12:38 PM
I would call Mallory and ask them about using a return line on that pump, I don't think it has enough power to feed a good size motor at WOT and use a return style regulator I hope I'm wrong I have used that pump before on a stock stroke 440 with 906 heads and a single four barrel set up, 2 3/8 feed lines into two Fram fuel filters Y into the pump #8 line to the Mallory two port regulator they recommended, that set up was marginal on that combination
Re: Fuel system setup questions [Re: Ron Silva] #424231
07/31/09 02:38 PM
07/31/09 02:38 PM
Imlay City, MI
DTT Offline OP
super gas
DTT  Offline OP
super gas
Imlay City, MI
Ron.
Thanks! I hadnt thought about that...Im gonna try it and see how it works.
Re: Fuel system setup questions [Re: DTT] #424232
07/31/09 05:31 PM
07/31/09 05:31 PM
CA
62SAVOY Offline
62SAVOY  Offline
CA
Maybe try these?
http://www.jegs.com/i/Earl%26%23039%3Bs/361/9892086/10002/-1
http://www.jegs.com/i/JEGS/555/100222/10002/-1
This one is kinda like what was shown in a earlier post.
Re: Fuel system setup questions [Re: Cab_Burge] #424233
07/31/09 05:42 PM
07/31/09 05:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
um, i'm over 700 hp and run a mal 140 and return style reg. -8an to and from with a stock tank and a 1/2 inch pickup. my fuel pressure is rock steady at over 130 mph
Re: Fuel system setup questions [Re: sixpackgut] #424234
07/31/09 08:31 PM
07/31/09 08:31 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I have a return style regulator that is DOWNSTREAM of the carb and does not kill any of the flow going to the Carb. It is a BACKPRESSURE Regulator and may work for you.
SRT DEMON ONE SEAT
Re: Fuel system setup questions [Re: Ron Silva] #424235
07/31/09 08:42 PM
07/31/09 08:42 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That is exactly how I did mine and used a comp 140 with -08 pressure and return and I have no issues running 10.00@131.00
Re: Fuel system setup questions [Re: Ron Silva] #424236
07/31/09 09:01 PM
07/31/09 09:01 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
mine is the same way
Re: Fuel system setup questions [Re: sixpackgut] #424237
08/03/09 05:36 PM
08/03/09 05:36 PM
Imlay City, MI
DTT Offline OP
super gas
DTT  Offline OP
super gas
Imlay City, MI
Ive ran this setup for about a year without any real issues. I just decide to change my fuel cell and figured Id see if I should up the size of my return while Im at it along with any other changes....I am running a 3/8 return and 1/2 feed.... My regulator is the backpressure type too...
Should I up the size of my return to 1/2 (-8) as well???
and I still havent decided if Im going to remove the foam or not....... Thanks
