Steering pump - pressed or keyed? #424203
07/30/09 05:48 PM
07/30/09 05:48 PM
SeventySatellite Offline OP
I will be getting bracket, pulley and Saginaw pump. Need to know whether to get pressed or keyed?
Re: Steering pump - pressed or keyed? [Re: SeventySatellite] #424204
07/30/09 06:06 PM
07/30/09 06:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Tricky, as I've seen/had both on Saginaws, and Federal pump,.........you know the drill, whatever you buy will be the opposite of what you need when you go to put it together,....never fails
Mike
Re: Steering pump - pressed or keyed? [Re: DAYCLONA] #424205
07/30/09 06:51 PM
07/30/09 06:51 PM
My understanding is that the keyed style allows you to bolt the pulley on? I guess if I can choose either way I'll choose the bolt, rather than pressing the pulley on.
Re: Steering pump - pressed or keyed? [Re: SeventySatellite] #424206
07/30/09 07:04 PM
07/30/09 07:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....the keyed is more user friendly in assembly, if your getting all your stuff at one source, have them verify the correct pcs, and or pcs desired, noting sucks worst than to have mismatched parts!....that you can't assemble
