TIME DELAY IGNITION #424039
07/30/09 04:16 PM
07/30/09 04:16 PM
Yocumtucky,PA
moparbo Offline OP
moparbo  Offline OP
Yocumtucky,PA
Hey gang. I just got a 69 Charger a little while back and it is a A01 light package car. One of the things I saw was that a lightt package car got a time delay ignition. My questions are what is it and what does it do? Thanks in advance!!!!
There's no "I" in team..........but there's "ME"
Re: TIME DELAY IGNITION [Re: moparbo] #424040
07/30/09 05:44 PM
07/30/09 05:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Light above ign switch, comes on for open door or when dome lights are turned on at headlight switch. Stays on then after closing door or turning dome light switch off. Stays lit for 20 seconds to a minute or so.
Re: TIME DELAY IGNITION [Re: buildanother] #424041
07/30/09 10:42 PM
07/30/09 10:42 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
It looks like a flasher "can" and is near the radio in the harness.
I want my fair share
Re: TIME DELAY IGNITION [Re: moparbo] #424042
07/31/09 12:19 PM
07/31/09 12:19 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: TIME DELAY IGNITION [Re: 72roadrunnergtx] #424043
07/31/09 04:15 PM
07/31/09 04:15 PM
Yocumtucky,PA
moparbo Offline OP
moparbo  Offline OP
Yocumtucky,PA
Is there a light on the 69 Charger by the ignition switch? I know there is one on the column mounted key switches for the later years. If there is a light I didn't see it.
Re: TIME DELAY IGNITION [Re: moparbo] #424044
07/31/09 04:21 PM
07/31/09 04:21 PM
chicagoland,usa
chicagoland,usa
If it is supposed to have it, it will be right above the ignition switch right on top of the 1/2 inch hole in the pad.
Re: TIME DELAY IGNITION [Re: buildanother] #424045
07/31/09 11:50 PM
07/31/09 11:50 PM
Yocumtucky,PA
moparbo Offline OP
moparbo  Offline OP
Yocumtucky,PA
Cool! I'll see if I can get it working. Thanks!!!!
