Re: Electric Fuel Pump - Suggestions
[Re: MONC]
#423742
07/30/09 11:39 AM
07/30/09 11:39 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Dont get a Holley if you want to hear anything else.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: MONC]
#423744
07/30/09 12:58 PM
07/30/09 12:58 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Meaning, even with flowmasters you will constantly hear the droning of the fuel pump. You may say it is ok now, but...
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HemiRick]
#423745
07/30/09 01:12 PM
07/30/09 01:12 PM
Posts: 25 Delaware
crazy4carz
Delaware
X2 I just removed one (Holley) of mine. I had two. One running the carbs and the other for the nitrous system, I left the Nitrous, but replaced the carb pump with a Malory. Much better.
[Re: HealthServices]
#423750
07/30/09 03:10 PM
07/30/09 03:10 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Get a mallory 110. Barely can hear it and a good pump too.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: MONC]
#423754
07/30/09 03:56 PM
07/30/09 03:56 PM
RapidRobert
Regarding hooking up the electrical part of it, is it straightforward?
yes, switched/fused 12V. EDIT I would wire in an on/off toggle sw in series(w the switched 12V) so you can keep it seperate from the ign sw to control it if needed
[Re: Dragula]
#423756
07/30/09 11:10 PM
07/30/09 11:10 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Is your Dart a very stock eng ? I only ask to know if you want a pump with built in regulation and no seperate regulator. I can say I use the Holley red pump that has the built in regulation on my sons Dart and my 63. It feeds both of them fine and they are mid 11 cars. As for fuel pump noise...........I grew up in the 60's and 70's and if you did not hear the electric pump it was not working. So a little fuel pump noise means nothing to me on my hot rod. That way I know it works. But I thought you may be looking for a pump that needs no seperate regulator. Ron
[Re: MONC]
#423757
07/30/09 11:58 PM
07/30/09 11:58 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Electric pumps are PUSHERS, so out back near the tank and down low if feasible......
I've heard some pretttttty loud fuel pumps in my day! I had a Carter once that was fairly quiet, but NO idea what part# it was or anything...
CrAzYMoPaRGuY
[Re: MONC]
#423759
07/31/09 01:00 PM
07/31/09 01:00 PM
Posts: 4,793 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Holy crap- the Holley is like someone running an air chisel in the trunk or like driving over rumble strips!
Keep old mopars alive.
