Will stock iron hemi heads work on a 572" engine?
#423715
07/30/09 10:09 AM
07/30/09 10:09 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I am in the planning stage for a 528 or a 572. I have a world block which will be 4.500 bore. I have stock cast iron heads. I don't have crank,rods, or pistons yet. The question is should I make it a 528 or a 572? I am definately using the stock heads but will do a mild port to them. Will the stock heads flow enough for a 572 or would the 528 be a better choice? Any suggestions?
Chris from New Jersey
Re: Will stock iron hemi heads work on a 572" engine?
[Re: fig426]
#423716
07/30/09 10:27 AM
07/30/09 10:27 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I had to edit my response as I guess it wasn't very clear. Stock heads aren't very good on the CID they were designed for,why build larger and think it won't be a bigger restriction? If you don't want to make HP they will be fine.
[Re: fig426]
#423717
07/30/09 11:36 AM
07/30/09 11:36 AM
Posts: 4,848 Memphis
HemiRick
Memphis
From what I've read the stock heads were oversized for a 426 and the 528 makes better use of the potential that is there. I'm not sure if a 572 crosses over that line.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#423719
07/30/09 01:34 PM
07/30/09 01:34 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Wasn't there a MM issue a couple years ago that showed a well respected SS racer using well worked 68 hemi heads on his 8 sec car????
[Re: imfixinmopars426]
#423722
07/30/09 05:52 PM
07/30/09 05:52 PM
fig426
East Coast, NJ
So the stock iron heads, mildly ported, would work better on a 528 than a 572?................................ Or should I put them on a wedge? Ha,,, Sorry Goldmember,, I just had to add that.
[Re: fig426]
#423723
07/30/09 09:41 PM
07/30/09 09:41 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
I would call Dwayne Porter, Porter Racing Heads, or Jeff at Modern Cylinder Heads and talk to them. I know diddly about iron Hemi heads, but I am reworking a 528 crate motor. The aluminum MP heads on the crate(not the newer EBrock) flow barely 300 cfm on the intake. after CNC porting they flow 440. I don't know if these heads are just lousy, or if the older iron heads were any better, but if that is all they have, you are going to need a full port job to take advantage of either displacement. Just my .02.
[Re: 3ddart]
#423726
08/01/09 12:35 PM
08/01/09 12:35 PM
Posts: 12,431 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would do the 572 and just do a little port job like you said, then a couple years down the road when you have the itch to go faster you pull the heads and have them profesionally ported and add a bigger cam. Hemi heads can flow incredible amounts of air even in stock form.
I am doing something similar with my small block, as many cubes as I can afford (414) Wiseco forged pistons, billit crower rods, mopar forged crank... and the heads I have are good for mabey 500 hp but the short block is super stout for later upgrades, I think my block will be the limit. When I get the money RyanJ will port my heads add bigger valves and I will put on a single plane and bigger carb and cam.
