Re: Indy maxx block problems, cam bearings spun.... [Re: stickshifter] #422880
07/30/09 09:03 AM
07/30/09 09:03 AM
Plymouth Meeting, PA
bigtimeauto Offline OP
Trophy Winner
Trophy Winner
Lets not forget haveing to put teflon tape on my header bolts!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Indy maxx block problems, cam bearings spun.... [Re: bigtimeauto] #422881
07/30/09 11:03 AM
07/30/09 11:03 AM
NYC
Dartari Offline
Dartari  Offline
NYC
This is why I went with a KB block.
Re: Indy maxx block problems, cam bearings spun.... [Re: bigtimeauto] #422882
07/30/09 11:54 AM
07/30/09 11:54 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Bob,
From the picture it really doenst look that bad. If the bore measured +0.006, are you sure you can't get a set of oversized bearings to work?
Regards,
Mike
8.30's @3400 lbs
Re: Indy maxx block problems, cam bearings spun.... [Re: Mike Swann] #422883
07/30/09 12:09 PM
07/30/09 12:09 PM
Trophy Winner
Trophy Winner
The durabonds are +.010 OD so i have to bore the tunnel to the correct size.
Re: Indy maxx block problems, cam bearings spun.... [Re: Mike Swann] #422884
07/30/09 01:30 PM
07/30/09 01:30 PM
something doesn't sound quite right. if the bore is .006" oversize, the bearing would FALL out of it. there would be no press fit at all.
Re: Indy maxx block problems, cam bearings spun.... #422885
07/30/09 02:58 PM
07/30/09 02:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I figured he meant .0006 oversize. But even then loctite wouldnt hold it in...
Re: Indy maxx block problems, cam bearings spun.... #422886
07/30/09 04:34 PM
07/30/09 04:34 PM
Trophy Winner
Trophy Winner
exactly. in the picture it spun and was gslled up
