727 output shaft bearing snap ring fix? #422815
07/29/09 09:53 AM
07/29/09 09:53 AM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
Anyone knows a fix for old snap rings (the ones that hold the bearing) on the output shaft that spinned and cut into the output shaft? I got 2 output shafts that got a to small diameter where the snap ring is and now also brand new snap rings are spinning. Is there a smaller snap ring I could use that fits and still holds the bearing in place?
Re: 727 output shaft bearing snap ring fix? [Re: 6o4o] #422816
07/29/09 11:00 AM
07/29/09 11:00 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
the snap rings that hold the bearing in place are not supposed to be tight on the shaft. All they need to do is hold the bearing in place. As long as there is no for and aft movement of the bearing on the shaft it'll be fine.
Re: 727 output shaft bearing snap ring fix? [Re: WILD BILL] #422817
07/31/09 03:58 AM
07/31/09 03:58 AM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
As much as I learned about snap rings they are supposed to be tight and not spin. The output shaft does and WILL move forward/backwards and push the bearing on that snap ring. So the snapring will spin sometimes. And I got 2 output shafts that got totally eaten up grooves from snap rings that were spinning on it. So everytime I got a snap ring that spins I throw it away. They are still available new from Mopar (pricy!). But on those 2 output shafts even the new snap rings are totally loose because the groove is cut to deep. That’s why I was looking for a solution to this…
Re: 727 output shaft bearing snap ring fix? [Re: 6o4o] #422818
08/01/09 02:16 PM
08/01/09 02:16 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Then a new shaft is your solution , but as said it's not an issue .
