340 stock intake & choke setup #421648
07/28/09 11:23 AM
07/28/09 11:23 AM
3
340clone Offline OP
340clone  Offline OP
I want to install a manual choke on my original stock cast iron 340 intake with AVS carb. Can I bolt the choke assembly directly to the intake or do I need to use a cup with seal in between?
Thanks!
Re: 340 stock intake & choke setup [Re: 340clone] #421649
07/28/09 11:30 AM
07/28/09 11:30 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'm not positive is the gasses can come up thru the well. I dont think so, but I'm not positive (good question...lol). If it's cable you can always make a bracket to hold it and bolt it to the pass side rear carb stud...
Re: 340 stock intake & choke setup [Re: moper] #421650
07/28/09 11:45 AM
07/28/09 11:45 AM
3
340clone Offline OP
340clone  Offline OP
The well is solid. (part of the casting of the intake)
Re: 340 stock intake & choke setup [Re: 340clone] #421651
07/28/09 03:36 PM
07/28/09 03:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
bolt it on.
Re: 340 stock intake & choke setup [Re: 340clone] #421652
07/28/09 03:54 PM
07/28/09 03:54 PM
Minneapolis, MN
W
WHLChallenger Offline
W
Minneapolis, MN
What year 340 are you talking about? On my '72 340 with orginal cast iron intake I am pretty sure there is a stamped tin cup that sits in the opening on the intake. This cup has a gasket that keeps the gases from leaking out of the cross over cavity.
Re: 340 stock intake & choke setup [Re: WHLChallenger] #421653
07/28/09 04:04 PM
07/28/09 04:04 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
My 71 cast intake the well is open if you remove the cup.
