TTI Header/Torsion Bar conflict #421568
07/28/09 08:49 AM
07/28/09 08:49 AM
NY
71Dart6Pack Offline OP
NY
Anyone had any issues with the #7 cylinder tube, which is a slip tube, not clearing the torsion bar with the small block step 1 5/8" headers? What did you do? Everything fits like a glove except for this. The torsion bar is a 1" firm feel bar and the car is a 71 dart. I can't ding the tube because it's right at that slip connection.
Re: TTI Header/Torsion Bar conflict [Re: 71Dart6Pack] #421569
07/28/09 08:54 AM
07/28/09 08:54 AM
The bigger bar is part of it--with the skinny Drag race bars they still just touch--I know..$700 bucks for headers that don't fit...can you say..HammerTime! Really ..with the pre 73 mounts you can "twist" the engine down on that side a little ( loosen both mounts and pull up on pass side of engine to shift it )but I had to hammer tune mine. Good luck!
Re: TTI Header/Torsion Bar conflict [Re: ] #421570
07/28/09 09:03 AM
07/28/09 09:03 AM
NY
NY
yeah it's a spool mount k frame unfortunately, so the hammer is probably the only option I guess. just sucks. I guess they forgot to mention that the larger torsion bars could be an issue.
Re: TTI Header/Torsion Bar conflict [Re: 71Dart6Pack] #421571
07/28/09 09:34 AM
07/28/09 09:34 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I have 1.04s and no issues. I was able to adjust the motor mounts so the tube is in between the t bar and the frame. Great fitting piece for me.
Re: TTI Header/Torsion Bar conflict [Re: 71Dart6Pack] #421572
07/28/09 09:36 AM
07/28/09 09:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd call them and ask what they think you should do. For the money TTi charges their stuff should jump from the box and install itself. If you have to "ding it" what's the point. You can buy $200 headers for that. Good luck.
Coming soon!!!!
Re: TTI Header/Torsion Bar conflict [Re: Mr.Yuck] #421573
07/28/09 10:34 AM
07/28/09 10:34 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I think the TTI headers are a rip off. I used a set of TPIS headers on my 92 Vette they were the most expensive headers I ever bought at $750 but they went in in about 20 minutes so I thought I would never buy a cheap set of headers again because the TPIS headers were perfect. Well TTI taught me otherwise. They just give you enough info to get you to buy them and yes you to death the whole way. I told them everything I had on my motor and they said they would fit fine. Then during install I find out they don't work with head studs so I had to take them out and replace a couple head studs with bolts. They said they would work with an OEM starter yea right I had 3 mini starters here none of them would fit so I had to buy another mini starter for I think $200 and still had to bend one of the tubes so it wasn't sitting on the starter. All in all it took 2 day and about 10 phone calls to Sam at TTI to put the headers in. the last call I had with sam ended with if I have one more problem with these headers I am going to throw the thru your window what a joke. Then to top it all off I ordered the nickel plated headers because I hate the look of rusty headers I wiped the headers down with alchohol before fire up like they said and the damn things turned brown at first glance they look rusted I hope I can find something to clean them up with
Re: TTI Header/Torsion Bar conflict [Re: Boise Chall] #421574
07/28/09 11:00 AM
07/28/09 11:00 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
I have the later spool mounts in my Dart w/the stock /6 t-bars and have no clearance issues w/the #7 tube. Very pleased w/fitment.
Re: TTI Header/Torsion Bar conflict [Re: Pntastar69] #421575
07/28/09 01:53 PM
07/28/09 01:53 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I love my s/b tti's.
they fit perfectly and were installed in less than an hour.
did you measure where the engine sits in the bay first,as per instructions?
Re: TTI Header/Torsion Bar conflict [Re: west] #421576
07/28/09 05:32 PM
07/28/09 05:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
must be an a-body thing. I've never measured squat in any set of b-body headers I've installed..
Coming soon!!!!
Re: TTI Header/Torsion Bar conflict [Re: west] #421577
07/29/09 12:18 AM
07/29/09 12:18 AM
NY
NY
the engine is sitting perfect. Also called tti....they were no help. Ended up breaking out the hammer .
Re: TTI Header/Torsion Bar conflict [Re: 71Dart6Pack] #421578
07/29/09 12:23 AM
07/29/09 12:23 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
show us a pic when you are done.
Re: TTI Header/Torsion Bar conflict [Re: west] #421579
07/29/09 03:48 AM
07/29/09 03:48 AM
For my money tti's are the best out there,my #7 tube touchs ever so slightly on the driverside torsion bar,but thats from launching it so hard at the track,no big deal still worth all the money i spent..and still look great after 3 seasons
Re: TTI Header/Torsion Bar conflict #421580
07/29/09 06:39 AM
07/29/09 06:39 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i had a problem in my 74 satellite with their headers, when i ran a small block. the top two tubes had to be mashed almost flat for the header to fit. i sent the header back and they worked with me and sent me a custom header back. and yes for the money they should drop in like a glove. with a set of $200 hedmans i had to ding them and mash them in no less than 17 spots to get them into the car.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: TTI Header/Torsion Bar conflict #421581
07/29/09 09:32 AM
07/29/09 09:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
for the money nothing should hit. Close only counnts in horseshoes and handgrandes.
My $109 headers fit w/o a dent or a dimple.
Coming soon!!!!
Re: TTI Header/Torsion Bar conflict [Re: Mr.Yuck] #421582
07/29/09 02:36 PM
07/29/09 02:36 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
think about it.what is more likely?
the headers are junk and all are built to different specs.
or the car is bent or the engine is not sitting in the optimal spot.
Re: TTI Header/Torsion Bar conflict [Re: 71Dart6Pack] #421583
07/30/09 12:13 AM
07/30/09 12:13 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I had no idea a torsion bar could be "clearanced" with a hammer..
Re: TTI Header/Torsion Bar conflict [Re: Mr.Yuck] #421584
07/30/09 12:24 AM
07/30/09 12:24 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Get a b-body,3" stuff fits like a glove.
Re: TTI Header/Torsion Bar conflict [Re: west] #421585
07/30/09 02:55 AM
07/30/09 02:55 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
That was my case - had to give my .990 bars a little "tweaking" after I installed my 383 into my Duster.
Ride eternal, shiny and chrome
Re: TTI Header/Torsion Bar conflict [Re: DirectSubjection] #421586
07/30/09 03:12 AM
07/30/09 03:12 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
and they are now junk
Re: TTI Header/Torsion Bar conflict [Re: Mr.Yuck] #421587
07/30/09 03:30 AM
07/30/09 03:30 AM
Ya,and they probably hit every pothole,bump,or speed bump and have all kinds on dings and dents..while tti's sit nice and high hitting nothing and still looking new after 3 years,bet yours are all rusted..pay $109.00 4 times or $650.00 once and never need another header again..
