Points to Electronic ? #421541
07/28/09 08:38 AM
07/28/09 08:38 AM
Arkansas
beatupcuda Offline OP
Arkansas
Whats a good setup to replace my dual point with electronic in my perf engine ?
Re: Points to Electronic ? [Re: beatupcuda] #421542
07/28/09 08:42 AM
07/28/09 08:42 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
MSD Pro Billet hands down . Use the 7AL for race , or 6 AL for street / mild race.
IMHO
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Points to Electronic ? [Re: beatupcuda] #421543
07/28/09 10:09 AM
07/28/09 10:09 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
For a performance street car a MP electronic conversion kit and an MSD blaster coil is all you need. Big block small block??
Year of car?
http://chucker54.stores.yahoo.net/eligpa.html
Mancini has Mancini kits that come with coil and plug wires!! new spark plugs and your off to the rodeo
http://chucker54.stores.yahoo.net/maraigspsmbl1.html
http://chucker54.stores.yahoo.net/moigsprbbl2.html
guess mopar does now too
http://chucker54.stores.yahoo.net/mope.html
Re: Points to Electronic ? [Re: Dodgem] #421544
07/28/09 10:16 AM
07/28/09 10:16 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
points to electronic
Re: Points to Electronic ? [Re: chryco] #421545
07/28/09 10:43 AM
07/28/09 10:43 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
IMHO
Chryco
I agree MSD pro billet, but I would go Digital 7
for racing and Digital 6+ for street use.
The Mopar dist and elect ign setup works also
but I would run MSD.
Snap your neck, mega G-force launch, is all I want!
Re: Points to Electronic ? [Re: BDS871Cuda] #421546
07/28/09 11:58 AM
07/28/09 11:58 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Std. Mopar. Parts are as close as your corner parts store.
Re: Points to Electronic ? [Re: MoparforLife] #421547
07/28/09 12:45 PM
07/28/09 12:45 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Petronix makes some really good products. I have used them several times. Not in recent years though. Pretty stealth if you want it to look stock.
I want my fair share
Re: Points to Electronic ? [Re: Dodgem] #421548
07/28/09 02:08 PM
07/28/09 02:08 PM
Arkansas
Arkansas
Thanks, I have read on these Items, just wondered about, MP parts, I see, orange, black, & chrome boxes, possibly making more or less available rpm limits, I thought my dual point, and Mopar perf coil would do the job, except I have been told it's probably going south about 4000 rpm, in the early 70's this seemed to work just fine. I do like msd, but really only need 7000 limit, and have just about spent all my $$$ on this 426 hemi already.
68 Hemi 4 speed Cuda,,,,building ?
Re: Points to Electronic ? [Re: beatupcuda] #421549
07/28/09 04:28 PM
07/28/09 04:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well since you went HEMI get a 6 AL and blaster coil the rev limiter is worth the extra few bucks!
Re: Points to Electronic ? [Re: Dodgem] #421550
07/28/09 04:40 PM
07/28/09 04:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
MP electronic with orange box. If your reving that motor over 6000 your wasting your time and motor. Hemi's are torq monsters. They make there power down low. If it were a 340 i'd say rev the [Edited by Moparts - Family Friendly Site - Keep it clean]. You don't need a million dollar ignition on a street motor unless your looking for bragging right's.
Re: Points to Electronic ? [Re: Dougsmopars] #421551
07/28/09 05:49 PM
07/28/09 05:49 PM
central ohio
N
nss guy Online happy
nss guy  Online Happy
N
central ohio
I switched from factory dual point to Pertronix in my 64 mw, ran great and easy install. A few years later I "upgraded" to MSD 6Al and saw no difference in ET the only benefit was the rev limiter. I go with the Pertronix if you like the factory look.
Re: Points to Electronic ? [Re: nss guy] #421552
07/28/09 07:32 PM
07/28/09 07:32 PM
Pertronix if the shaft/bushing play is acceptable & if not a rebuilt points 383 one might be cheap or a common oe electronic one w a MP chrome box & recurve it(springs/slot length)for your combo
Re: Points to Electronic ? [Re: SomeCarGuy] #421553
07/28/09 10:23 PM
07/28/09 10:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Pertronix or a ProComp ready to run distributor. They can be had for $50-70 off that auction site. Why clutter up a nice hemi engine bay with all the wiring/electronics of the stock chrysler system? Keep it all in the distributor so it stays neat, tidy and clean.
Re: Points to Electronic ? [Re: Dougsmopars] #421554
07/29/09 12:22 PM
07/29/09 12:22 PM
Arkansas
Arkansas
Well Doug, my comp cam is good from 2500 to 6500, so that's where my concern of up over 6 comes from. Not looking for bragging rights, just want great spark at 6500 for sure.
If I go MSD the box will be under the dash, not in the engine comp, still hard to believe my dual point, & hot coil will not do the trick, but it appears everyone goes electronic. I really don't like the vacumm advance pod on the newer elect dist, course I think I can remove it ? and go all mech ? any suggestions on this ?
Re: Points to Electronic ? [Re: beatupcuda] #421555
07/29/09 12:41 PM
07/29/09 12:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes get a MSD with no vacuum advance on a MP weld the plates together and you can remove the vacuum advance and make a little cover for the hole
Re: Points to Electronic ? [Re: Dodgem] #421556
07/29/09 01:39 PM
07/29/09 01:39 PM
Arkansas
Arkansas
Well Dodgem, I like the stock look, and with the MP dist, I keep the cap for my wires, otherwise the new MSD = new wires, and I have read where the blaster should be mounted up right vs horiz.
I think if I go MP I'll get the chrome box, I think that kit from Manz is about 220, then another coil.
thanks
However I think MSD is the way to go.....
Re: Points to Electronic ? [Re: beatupcuda] #421557
07/29/09 03:44 PM
07/29/09 03:44 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dam glad you told me my MSD (blaster 2 I think???) is mounted horizontal for 15 + years and does not break down at 8000 rpm. I'm leaving it I don't like change!
Re: Points to Electronic ? [Re: Dodgem] #421558
07/29/09 03:48 PM
07/29/09 03:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well with were you are going 6000 to 6500 probably mostly cruising why not MP. I still not fussy on vacuum advance. I once cut the arm off welded the plates together and left pot on heck you could block the vacuum line and put it on ported vacuum of carb so it looks stock!
Re: Points to Electronic ? [Re: Dodgem] #421559
07/29/09 08:03 PM
07/29/09 08:03 PM
SomeCarGuy Offline
SomeCarGuy  Offline
My Blaster 2 is horizontal
why can't you run vac advance?
Re: Points to Electronic ? [Re: beatupcuda] #421560
07/29/09 08:07 PM
07/29/09 08:07 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Tribute, you need stock dual point like mine. Check it out.
