Re: Proportioning valve question
[Re: Ron Silva]
#421473
07/28/09 03:37 PM
07/28/09 03:37 PM
Posts: 1,880 USA
Ron Silva
USA
Smaller piston = higher brake fluid pressure. It's basic physics. You have the brake pedal, a lever (and leverage ratio), and a piston. Just think if the MC piston were 4" in diameter VS if it was 1/4" in diameter.
SRT DEMON ONE SEAT
[Re: B G Racing]
#421477
07/28/09 04:23 PM
07/28/09 04:23 PM
Posts: 2,128 sweden
sshemi
sweden
The master cylinder volume is to displace the area of the of the pistons or wheel cylinders.A proportioning valve controls the pressure.A stock valve and a race valve do the same thing they open and close the passing orfice which controls the pressure,ie: putting your finger on a garden hose to increase the pressure.Small race calipers with small pucks can use a small MC(less area,less volume)large street calipers with large or multiple pucks need larger MC bores and resovires. By adjusting the size of the passing orfice(making it smaller) increases the pressure,usually in to increase and out to decrease on the race valves
So you sre saying that a propvalve is nothing more than a finger on the hose. Dont get me wrong here i want to learn this but wouldnt the finger keep the caliper pistons from returning and drag the rotors? Or is it a spring actuated valve of somekind?
[Re: sshemi]
#421480
07/28/09 04:37 PM
07/28/09 04:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It is like putting your finger over the hose BUT with the brakes its going into a closed area(line and caliper) SO the pressure will equalize on both sides of the valve after a giving period of time. All that valve is is a delay on the pressure... in hyd, the pressure will equalize
[Re: Otherlane]
#421482
07/28/09 05:05 PM
07/28/09 05:05 PM
MR_P_BODY
So without a prop valve you will have the same pressure at all 4 corners? the same stopping power at all 4 corners?
Yes if the pistons in the master are the same, the only difference would be the size of the caliper pistons or wheel cylinder sizes... but if the master pistons are the same you have the same PRESSURE
[Re: Otherlane]
#421483
07/28/09 05:08 PM
07/28/09 05:08 PM
Posts: 1,880 USA
Ron Silva
USA
Not necessarily the same stoping power. I have the same calipers at all 4 wheels but my front rotors are 10-1/2" and the rear rotors are 12+" so the rear will have more stopping power. Gee maybe that is why I don't have the need for a porportioning valve since I run big&little tires...........
SRT DEMON ONE SEAT
[Re: Ron Silva]
#421484
07/28/09 05:13 PM
07/28/09 05:13 PM
MR_P_BODY
Very true, the farther you get from the centerline the easier it is to stop the same mass
[Re: Otherlane]
#421486
07/28/09 05:25 PM
07/28/09 05:25 PM
Quicktree
With that being said would it be harder to do a burnout without a prop valve?
has nothing to do with it. only thing is there is not much front tire contact and if you don't get enough water on the slicks it will sometimes push the front tires.
[Re: Otherlane]
#421487
07/28/09 05:38 PM
07/28/09 05:38 PM
MR_P_BODY
You just have to hold the brake pedal a little longer for the pressure to get to the fronts(remember it will equalize)... most people including myself pump the pedal a few times and hold it then press the line lock
[Re: MR_P_BODY]
#421488
07/28/09 05:52 PM
07/28/09 05:52 PM
Quicktree
huh
[Re: Quicktree]
#421489
07/28/09 06:20 PM
07/28/09 06:20 PM
MR_P_BODY
huh
Tony.... if you have a prop valve in the fronts the pressure will be SLOW getting past the prop, then it will equalize after X period of time
[Re: sshemi]
#421490
07/28/09 06:37 PM
07/28/09 06:37 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Your not comprehending this at all,the pressure is only when the piston is depressed in the master cylinder which inturn pushes the fluid through the system pushing the pucks and applying the brakes,when the pedal is released so is the pressure,simply theory of hydraulics pressure applied through the pedal ratio,applied through mc bore/stroke,controlling a given volume at a given pressure.Change in pressure can be regulated by the size of orfice it passes through.The small orfice holds back the volume(under pressure) and the orfice creates the additional pressure.ie: a nozzle on a fire hose or pressure washer.Sorry I can't explain it any simpler,hope it helps you understand.Another example would be a diesal fuel injection system where as a pump generally pumps fuel at 45psi to the injector nozzle the nozzle orfice releases fuel at 1800psi.
