Re: Turbo Cuda 7.30 @ 195
[Re: go green]
#420515
07/27/09 07:18 PM
07/27/09 07:18 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
At 3000 lbs which were the rules for SSCN.
In regular PSCA, small blocks with centrifugals have a 2800lb minimum weight. You will have to be 3100lb for twin turbo and 547 ci.
Also, Sikora was at 3000 lbs when he ran the 6.63 in Chicago. He's got it dialed in
Good luck to you.
8.30's @3400 lbs
[Re: Mike Swann]
#420516
07/27/09 07:34 PM
07/27/09 07:34 PM
Posts: 778 Sherwood park, Alberta.
go green
Doug Sikora has definetly found some more speed . He now has Ron Weems and Rich Zehring covered. I am at 3115 pounds , all factory glass and stock dash with the AM radio. I dont have the money or resources to set the world on fire , I just might have enough to get it to smoke a little.
[Re: go green]
#420517
07/27/09 07:59 PM
07/27/09 07:59 PM
Mike Swann
Long Beach, CA
You biggest problem is going to be getting all of that power to the ground AND 60 ft. Also, it wouldn't hurt to get it to 3020, ready to run.
Finally, Are you sure your AFR is calibrated properly? Seems to me your richer that the UEL of either gasoline or ethanol.
8.30's @3400 lbs
[Re: go green]
#420521
07/27/09 09:21 PM
07/27/09 09:21 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: go green]
#420528
07/27/09 09:50 PM
07/27/09 09:50 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
WOW
Sweet congrats
[Re: go green]
#420531
07/27/09 10:48 PM
07/27/09 10:48 PM
Posts: 846 Long Island, NY
Cudafied
Long Island, NY
You know what they say "Where There's Smoke There's Fire"
