Page 148 of 167 1 2 146 147 148 149 150 166 167
Re: New Paint job on a budget thread Part III [Re: RoboGeek] #39254
12/26/09 09:57 PM
12/26/09 09:57 PM
middleOnowhere CA
THEYOUNGGUN53 Offline
middleOnowhere CA
its getting there, I need to fix a few things on the roof as it was the most beat up thing on the car.
Right now I'm focusing mostly on the interior, the dash is going to take the longest as I have a lot of fixing and back dating to do on it. I might get it done by summer, I just don't know which one
a car is never "done"
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39255
12/28/09 11:22 AM
12/28/09 11:22 AM
thats why I consider myself very lucky to live in Cali, rust scares the heck outta me!
you did a fantastic job though, did you need to replace the pans?
The pans were rusted though under the back seat, the rest or the pans were perfect, so I welded in new steel where the rust was while I had the body off the pan. My garage doesn't smell like mineral spirits now, It really wasn't that bad at the height of paint rolling activity. I rolled it outside and let it dry for an hour or two, then pushed it back in the garage till the next roll session.
Re: New Paint job on a budget thread Part III [Re: supraghost] #39256
12/28/09 01:22 PM
12/28/09 01:22 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
man, that supra looks awesome!
So can anyone tell me how this works on the urethane body parts like the lower valance, and rollpans on trucks?
I am practically ready to take the truck apart and get this done!!!!
Re: New Paint job on a budget thread Part III [Re: POS Dakota] #39257
12/28/09 09:27 PM
12/28/09 09:27 PM
Cornfields of Illinois
RoboGeek Offline
RoboGeek  Offline
I decided to do my ugly black stock bumpers and trim with the same semi-gloss that the lower panels are painted. Prepped them real good, allowed lots of drying time before painting (I fear porous plastic!) but it came out real good. No pics of it till spring though - car that was supposed to be my winter beater is now my 'summer' car, so its parked and buried under global warming
Re: New Paint job on a budget thread Part III [Re: RoboGeek] #39258
12/29/09 05:23 PM
12/29/09 05:23 PM
Arizona
tna Offline
tna  Offline
Arizona
After reading the first 20 or so pages of the thread I decided to try and repaint my bmw. I did a test run behind my license plate. I don't know if I thinned it enough? It looked very orange peely, and had some bubbles in it. Is this normal for the first coat or should I thin it more? I can post pics of my progress if anyone would like, I plan on doing the whole car if I get the hang of it.
Re: New Paint job on a budget thread Part III [Re: tna] #39259
12/29/09 05:39 PM
12/29/09 05:39 PM
usa
aussie Offline
aussie  Offline
usa
Please post pics, we would love to see the progress
Re: New Paint job on a budget thread Part III [Re: aussie] #39260
12/29/09 11:18 PM
12/29/09 11:18 PM
Arizona
tna Offline
tna  Offline
Arizona
So I now am pretty sure I did not thin the paint enough, it seemed pretty thin when mixing, but it felt thick when rolling it on? Maybe I just need some better technique. I got a lot of orange peeling, and some bubbles. There was a spot on the right side that looked and felt better than the rest though.
The picture was taken after a quick sand. It's also not very hard and I could easily peel it off. Which may just be because I laid it on too thick? I'm still very hesitant about doing the entire car. Here's a before picture also, so you can see why I am painting my car.
Re: New Paint job on a budget thread Part III [Re: tna] #39261
12/30/09 02:20 AM
12/30/09 02:20 AM
middleOnowhere CA
middleOnowhere CA
I would definatly thin it out some more, a 50/50 mix usually does it for me. Though I haven't painted much since its gotton cold out.
make sure you sqeez as much paint out of the roller before you touch the car to.
as for the hardness, paint takes much longer to dry in the cold.
also you would probably benifit a lot from more sanding, I'd go from 120 to 400 to 800 before painting. Take it down until theres no more shiny areas at all, maybe even some primer showing through. Prep is always key.
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39262
12/30/09 03:09 AM
12/30/09 03:09 AM
Arizona
tna Offline
tna  Offline
Arizona
Thanks, I think I did have too much paint on the roller. Luckily that was just a test area and can be covered by the license plate. I think I may start sanding for the real thing tomorrow.
Re: New Paint job on a budget thread Part III [Re: tna] #39263
01/01/10 05:13 AM
01/01/10 05:13 AM
middleOnowhere CA
middleOnowhere CA
don't forget the sanding block
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39264
01/02/10 11:51 AM
01/02/10 11:51 AM
western pa
tthunderdan Offline
tthunderdan  Offline
western pa
here is the 91 blazer I did with rustoleum/ thinner/ roller method about a year ago, it never gets washed the boy has it at college for now, more pics at
http://www.flickr.com/photos/8626355@N05/4236703811/
[image]http://www.flickr.com/photos/8626355@N05/4236703811/[/image]
Re: New Paint job on a budget thread Part III [Re: tthunderdan] #39265
01/07/10 10:33 PM
01/07/10 10:33 PM
middleOnowhere CA
middleOnowhere CA
finaly an update from me, I've been back dating the dash (getting rid of the late model vents and repairing the hacked up radio port)
first was the fiberglassing and removing of paint
then the body filler
<br>
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39266
01/11/10 11:42 PM
01/11/10 11:42 PM
middleOnowhere CA
middleOnowhere CA
filler sanded
and primerd
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39267
01/14/10 12:54 AM
01/14/10 12:54 AM
middleOnowhere CA
middleOnowhere CA
quick question, would it be possible to mix gloss paint and flat paint to creat a semi gloss look without any drying/adhesion/chemical reaction problems?
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39268
01/14/10 02:05 AM
01/14/10 02:05 AM
USA
_
_Scott_ Offline
_Scott_  Offline
_
USA
You'll have experiment with mix ratios to get the luster you are after, but otherwise there should be no problems.
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #39269
01/14/10 02:19 AM
01/14/10 02:19 AM
middleOnowhere CA
middleOnowhere CA
cool, thank you
88 Dodge Dakota [Re: THEYOUNGGUN53] #39270
01/14/10 11:44 PM
01/14/10 11:44 PM
619
LO619 Offline
LO619  Offline
619
I have been reading for a while... Currently working nearly everyday on painting my truck.
I have learned alot during the project and hope to contribute knowledge to the thread and get advice for my project.
HERES HOW IT LOOKED WHEN I GOT IT:
LATEST PIC:
5th coat on the bed panel. I am still getting orange peel, I will try to thin the mix a tad bit more, but it is a pretty this consistency.
When I started the project I was using this:
http://www.homedepot.com/Paint-Tools-Sup...catalogId=10053
I would avoid this product at all costs and the difference between this and normal "odorless" mineral spirits is night & day.
first difference is that the spirits are WHITE in color. I could never get a properly thinned mix, it always maintained a thicker consistency and when I did get it thin the paint completely lost it's shine. In comparison the coats with the "green" mineral spirits were much duller. I was always scratching my head to why, well now I know.
Also, for the brushes & paint trays I found the best place is Wal Mart, they have multi-packs of foam brushes for $1.50, which is great & 3 packs of roller trays for 1.50. The trays also seem a little thicker and tougher than the white ones I was using previously.
Re: 88 Dodge Dakota [Re: LO619] #39271
01/16/10 02:53 AM
01/16/10 02:53 AM
middleOnowhere CA
middleOnowhere CA
just did this today, I used a cheap hplv gun I bought at a garage sale for $5 and my dads air compressor. It came out WAY better than I expected. I'm very happy with the results!
Re: 88 Dodge Dakota [Re: THEYOUNGGUN53] #39272
01/16/10 04:44 PM
01/16/10 04:44 PM
619
LO619 Offline
LO619  Offline
619
Looks sweet. It that the white primer or rusto paint? are you going white on the exterior as well?
Re: 88 Dodge Dakota [Re: LO619] #39273
01/21/10 06:46 PM
01/21/10 06:46 PM
RoboGeek Offline
RoboGeek  Offline
never thought I'd say it - but I found a little rust on my 2002 cavy! PAINT JOB!!!
btw.. the 93 cavy winter beater hasn't been driven once this winter - its too pretty!!
You ever gonna finish that bug?? lol
