Re: Are 3.91's enough gear?
[Re: VITC_GTX]
#384916
07/24/09 11:00 AM
07/24/09 11:00 AM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
I would leave the Gears alone and just change the Converter. You say its 100% Street, and the 3.91's will have you buzzing down the freeway ~3300 rpms.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: VITC_GTX]
#384920
07/24/09 11:42 AM
07/24/09 11:42 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I would get the converter upgraded. (changed)
[Re: buildanother]
#384922
07/24/09 11:51 AM
07/24/09 11:51 AM
Posts: 1,414 Stow ,Ohio
demon440
Stow ,Ohio
I think you should finish one car before you tear apart another. Don't you have 2 or 3 projects going on right now? Or you could sell me your Demon.
[Re: VITC_GTX]
#384923
07/24/09 11:58 AM
07/24/09 11:58 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
What is your compression ratio? If your tune is good, the right converter and cam will do wonders with 3.54's.
What do you have the timing set at, initial and total? What do your plugs look like? You can easily change the cam and lifters with the motor in the car without removing the intake. You can always contact Dave over at Hughes Engines and talk to him about your set-up and see what he recommends.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 540challenger]
#384930
07/24/09 02:21 PM
07/24/09 02:21 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
You could also get a shorter tire 26" a 275/50/15 They are a little wider i think about a 1 inch off the top of my head.
it would be a real easy way to see how your car likes a higher gear and free if you could borrow a set.
[Re: challenger70]
#384932
07/24/09 02:31 PM
07/24/09 02:31 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
a 26" tire on a B-body would look silllllllly.
