Throttle Stop Launch #384514
07/23/09 06:53 PM
07/23/09 06:53 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Any ideas on setting up a way to basically have a mechanical 2-step for a manual trans car?
Looked at a solenoid,or a staged spring. Any thoughts?
Running a electric 2-step puts me in a different class.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Throttle Stop Launch [Re: 6bblFLASH] #384515
07/23/09 09:52 PM
07/23/09 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Can you run a air activated system
Re: Throttle Stop Launch [Re: 6bblFLASH] #384516
07/23/09 10:03 PM
07/23/09 10:03 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Got what you need in the garage - all you will need is a regulator for the CO2 bottle - it's yours when you want it
Re: Throttle Stop Launch [Re: DoubleD] #384517
07/23/09 10:46 PM
07/23/09 10:46 PM
N.E. Ohio
N.E. Ohio
Thanks Dave, I`ll have to check the rules first.
