8 3/4 housing width? #384420
07/23/09 04:53 PM
07/23/09 04:53 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
I am confused & the more I read makes it worst. LOL. The measurement from flange to flange with no
backing plate should be 52" for a A body,54" for a B body & 56" for a E body. Am I correct?
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 8 3/4 housing width? [Re: stickman] #384421
07/23/09 05:26 PM
07/23/09 05:26 PM
scratchnfotraction Offline
and 59" for trucks and c-bodys oh my!
did you look at the chart in the archives here on the board?
I know the c-body and truck is the same 59"
I have one from a 67 polara that is 56" with 30" axles..IIRC.. thinking its E-body,but a 67 polara is a c-body
I have an A-body one in my truck,had it cut and dont remember what it was for A-body specs
I cant get them straight either..and one of the charts was wrong
Re: 8 3/4 housing width? [Re: scratchnfotraction] #384422
07/23/09 05:30 PM
07/23/09 05:30 PM
Re: 8 3/4 housing width? #384423
07/23/09 06:11 PM
07/23/09 06:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 8 3/4 housing width? [Re: John_Kunkel] #384424
07/23/09 06:53 PM
07/23/09 06:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The correct info is here:
http://www.moparts.org/Tech/Archive/axle/16.html
Yep.
Someday, someone will give a cr@p enough to remove that chart from the server.
Re: 8 3/4 housing width? [Re: RobX4406] #384425
07/23/09 07:01 PM
07/23/09 07:01 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Thanks guys. The corrected chart is what I was looking for. It is simple enough for my brain to
understand.
