Titan copper gaskets #384246
07/23/09 01:24 PM
07/23/09 01:24 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I have a set of titan gaskets coming form my 0-ringed 440. (past thin gasket/shim post looked at them and no go) SCE say no spray needed on the titan.
Is that what everyone does just put them on with the proper 0-ring???
Thanks in advance
Re: Titan copper gaskets [Re: Dodgem] #384247
07/23/09 01:42 PM
07/23/09 01:42 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I am running the Titan that has the o'ring built in. So far so good. I only have about 70 miles on it.
Re: Titan copper gaskets [Re: stroked470] #384248
07/23/09 05:03 PM
07/23/09 05:03 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks this is the ones I'm getting.
http://www.summitracing.com/parts/SCE-T64383/
so you used no spray?
did you warm up cool and re torque???
Re: Titan copper gaskets [Re: Dodgem] #384249
07/23/09 06:05 PM
07/23/09 06:05 PM
Stow,Ohio
dodgemike Offline
dodgemike  Offline
Stow,Ohio
I am using a set on my smallblock. Motor going
back in the in the car soon. Their web site says
use no sealer.
Will have to let you know how it works out.
Re: Titan copper gaskets [Re: dodgemike] #384250
07/23/09 08:40 PM
07/23/09 08:40 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I'm hoping mine are hear and in by next friday!! I hope.
Re: Titan copper gaskets [Re: Dodgem] #384251
07/23/09 09:04 PM
07/23/09 09:04 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
Been using them for four years now. No spray.....Absolutely No, and I mean No problems with them. torque down, start engine, build temp to 180 degrees, and retorque. I am a very happy SCE customer.
Post deleted by Defbob [Re: savoyracer] #384252
07/23/09 09:09 PM
07/23/09 09:09 PM
Re: Titan copper gaskets #384253
07/23/09 10:28 PM
07/23/09 10:28 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Yes on the wire thickness they say 25% 0r less. so 032 is .008 or less. Think that was the water seal problem then the oil as I had .020 on a .043 gasket.
First time with o-rings and I new 25% but for some reason when doing it it never came to mind just bought .040 wire at the speed shop and installed it!
Brain fart I guess. going to check and see if .025 or .030 wire will work best!
I'll check to see if their inbossed seals covers the blocks big water holes
