904/999 transmission question #384057
07/23/09 09:33 AM
07/23/09 09:33 AM
East Lansing, Michigan
O
OldHippie Offline OP
super gas
super gas
O
How does one identify, externally, a 999 from a 904?
The Old Hippie Hisself
Re: 904/999 transmission question [Re: OldHippie] #384058
07/23/09 12:42 PM
07/23/09 12:42 PM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
Man, other than possibly the serial number, I think they are identical on the outside. Knowing what kind of car it comes out of can give a clue, but other than that, I don't know. Maybe others will chime in here that know much more than I have in my limited brain. I'm working on a 999 now - it came out of a police car. Sorry I couldn't be more help.
Re: 904/999 transmission question [Re: OldHippie] #384059
07/23/09 03:40 PM
07/23/09 03:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The trans can be identified by its part number which is stamped in the drivers side pan rail.
Re: 904/999 transmission question [Re: John_Kunkel] #384060
07/23/09 08:40 PM
07/23/09 08:40 PM
O
super gas
super gas
O
John, can you be a bit more specific? Is there a designation/digit that will ID the unit?
Re: 904/999 transmission question [Re: OldHippie] #384061
07/24/09 05:17 PM
07/24/09 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The first seven digits is the part number, it is often preceded by a PK or single letter.
Check this link for the application:
http://www.mymopar.com/downloads/transguide.pdf
Re: 904/999 transmission question [Re: OldHippie] #384062
07/24/09 07:23 PM
07/24/09 07:23 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
The following are part #'s for A999 trans.(non lock-up) These #'s are from the direct-connection chassis book.
'74-'75 3681844
'76-'77 4028465
'78 4028878
Re: 904/999 transmission question [Re: 360DOUG] #384063
07/25/09 09:28 AM
07/25/09 09:28 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Not to muddy the waters, but weren't all 998's and 999's lockups?
I was told one id'er is if the input shaft was hollow it was a lockup.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 904/999 transmission question [Re: Magnumguy] #384064
07/25/09 04:05 PM
07/25/09 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The A998 and the A999 were both introduced in '74, the lockup converter wasn't introduced until '78.
