Re: Need some carb? help w/ 588 B1 Top Sportsman motor... [Re: Al_Alguire] #383650
07/23/09 11:02 AM
07/23/09 11:02 AM
Oklahoma
silverfish Offline OP
Oklahoma
I would try to verify if the cam is a swap set up or a standard firing order cam. Although that would not really account for the plugs, but I am also a bit curious with two that seem to be ok...Does not make sense to me. I would think if it were a carb issue all the plugs would look the same, so I would imagine it is safe to say that is not the issue.
Yeah that was really weird to me to. The more I go into everything the more it sounds like an electrical issue or possibly the firing issue you speak of. To be honest I really didn't know that they made cams that had alternate firing orders. I don't know that I got a cam card with the motor when I bought it but Muscle Motors built the motor and I can probably find out about that from Mike.
Re: Need some carb? help w/ 588 B1 Top Sportsman motor... [Re: silverfish] #383651
07/23/09 11:21 AM
07/23/09 11:21 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I'll have to check into the cam specs, don't know on that. No I didn't hang a timing light on it to check to see if it is retarding as rpm builds. I have a 7531 box in my other car. Does anyone know if I can swap them out just for testing purposes? I know it has way more wiring but I am thinking that maybe the plugs are the same but the 7531 just has a couple extra ones??
should be an easy swap but you'll need to hook up a programmer to check all the rev limits. I would only hook up the wires necessary to fire the car, coil, crank trigger, main power and maybe two step if you want to check it. You do know the 7531 is illegal for bracket racing don't you?
Re: Need some carb? help w/ 588 B1 Top Sportsman motor... [Re: MegaDart] #383652
07/23/09 01:13 PM
07/23/09 01:13 PM
Oklahoma
Oklahoma
The 7531 is in my true ten five heads up car not a bracket car. I'm thinking ur right on the hookup though. I will try that tonight. The whole thing about the 7531 being illegal in a bracket car is why I don't have one of them in this car in the first place. I thought the 7520 would be the next best thing but maybe not!
Re: Need some carb? help w/ 588 B1 Top Sportsman motor... [Re: silverfish] #383653
07/25/09 03:29 PM
07/25/09 03:29 PM
Oklahoma
Oklahoma
PROBLEM SOLVED!!!! It ended up being the rotor phasing. I went out there today after work and checked the rotor phasing and it was off quite a bit! I pulled the dist loose and adjusted the belt to where rotor lined up correctly and the motor sounded like it was supposed to. It idles even better and will rev to the moon! I just gave it a quick blip that I thought would net about a 4 or 5k rev and the motor went past 8k in a heartbeat!! I guess the spark was scattering before and mixing up cylinders. I should have checked that sooner I guess but I just didn't know. I'm still learning about all this stuff. I really appreciate everyones input and ideas and willingness to help me with this. It speaks volumes for you character and I just hope that I am able to return the favor someday. Thanks again!
