ao1 light package #383259
07/22/09 05:02 PM
07/22/09 05:02 PM
texas
magnum440 Offline OP
texas
hello my light delay stopped working awhile back and i forgot how it works..thee yellow wires connect on a 3 way connector from light bar and steering column...gave them 12v with a power probe and both bulbs are good...is there anyway to test relay..does it work as a ground...if so ,is there supposed constant 12v somewhere...any help input would be apprecitated,,,tia..
Re: A01 Light Package [Re: magnum440] #383260
07/22/09 06:23 PM
07/22/09 06:23 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Maybe this will help.
Re: A01 Light Package [Re: Snoopy] #383261
07/23/09 12:52 PM
07/23/09 12:52 PM
texas
texas
thanks snoopy ,,yeh i see im missing the time delay ground ...also wondering where does M15-18p goes..thanks again
Re: ao1 light package [Re: magnum440] #383262
07/23/09 01:36 PM
07/23/09 01:36 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
While were on the subject
Anyone have the wiring diagram like posted for a 1971 Charger Superbee A01 Light Package - All the books and wiring diagrams i have , nothing
Trying to figure out my Ignition Key Lamp
Yellow wire thru steering column not connected to anything
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: A01 Light Package [Re: magnum440] #383263
07/23/09 02:10 PM
07/23/09 02:10 PM
Snoopy Offline
Snoopy  Offline
M5-18P goes to fuseblock by way of:
Rallye - cigar lighter & clock
Standard - cigar lighter
Re: A01 Light Package [Re: magnum440] #383264
07/23/09 02:24 PM
07/23/09 02:24 PM
Shoreline, Washington
72roadrunnergtx Offline
M15-18P? Is that M5-18P referenced on that wiring diagram? If so, that should be the unswitched (constant 12v) accessory power tap coming of the main dash harness, and should be fuse protected at the box. Should be a red colored flat three position female bullet type connector on a pink wire. How does the time delay relay work? The relay needs constant 12v on the pink wire (X1A-18P), when grounded on M6-18Y*(via the left door dome lamp switch) you should have 12v out on J5-18Y, to illuminate the ignition switch, for a minute or two then go out.
There is a bi-metal spring contact that is heated up to provide continuity to the light, even after the ground is removed (door closes) it takes some time for the spring contact to cool down and open the circuit. Sometimes the relays can be easily repaired if inop. Carefully remove the cover check and clean the contacts. If the heating coil is open, may have to find another relay.
bee1971, the relay/key lamp system had a separate wiring harness on the b-bodies, and with the relay itself was taped to the dash harness close to the ignition/turn signal connectors. If the relay and harness is present there should be a corresponding single connector on a yellow wire for the lamp lead.
From the 72' FSM
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: A01 Light Package [Re: 72roadrunnergtx] #383265
07/23/09 08:49 PM
07/23/09 08:49 PM
texas
texas
thanks again for input...i got it...it was door switches...they have two terminals so although they were turning on dome lite the other terminal wasnt grounding,,i just cleaned them and bingo ,,started working,,,if they act up again ill just get new door switches...
Re: A01 Light Package [Re: 72roadrunnergtx] #383266
07/23/09 09:55 PM
07/23/09 09:55 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx man
I will look into the seperate wiring harness/relay and see if its there
If its not , i am sure that would bee fun to find
Thanx Scott
Siberian Huskies
Re: A01 Light Package [Re: bee1971] #383267
07/23/09 10:26 PM
07/23/09 10:26 PM
I found this picture that may help identify components/connections.
Re: A01 Light Package [Re: 72roadrunnergtx] #383268
07/24/09 12:28 AM
07/24/09 12:28 AM
Snoopy Offline
Snoopy  Offline
Doug,
What year and model is that?
Re: A01 Light Package [Re: Snoopy] #383269
07/24/09 12:56 AM
07/24/09 12:56 AM
72’ Plymouth b-body , I assume the e-bodies were laid out in a similar fashion but not certain.
Re: A01 Light Package [Re: 72roadrunnergtx] #383270
07/24/09 02:20 AM
07/24/09 02:20 AM
Snoopy Offline
Snoopy  Offline
Thanks, I just wanted to label the picture for further reference.
Re: A01 Light Package [Re: Snoopy] #383271
07/24/09 10:44 AM
07/24/09 10:44 AM
Another angle, it should be noted, if not obvious, this is a non-rallye dash (pretty clean 72’ Satellite Sebring donor car). This dash harness was later converted to support a rallye dash and is currently in operation in my RR/GTX.
Re: A01 Light Package [Re: 72roadrunnergtx] #383272
07/24/09 12:58 PM
07/24/09 12:58 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Pictures are worth a million - Thanx
Just had my eyes under the dash - Was about to remove the radio when i saw what i needed
Great news - Everything is there - Looks like nothing has been touched since 1971 - All the wiring is there nice and pretty - The yellow lead for the light itself was connected just like in the picture I was looking originally at a different yellow wire - So thats the good news
Bad News - The Relay itself is missing - Someone removed the tape and the three prong wiring harness is just hanging there with no relay
Any suggestions on a part # from a local jobber ??
I appreciate all your insight
Thanx again - Scott
Siberian Huskies
Re: A01 Light Package [Re: bee1971] #383273
07/24/09 08:08 PM
07/24/09 08:08 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
2889565 time delay relay.
I might have a spare, I'll take a look this weekend.
Re: A01 Light Package [Re: charger440sixpak] #383274
07/27/09 01:38 PM
07/27/09 01:38 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx for the part #
I did a little research and then called my local dealer - He knew exactly what it was when i started reading off the part #
$14.40 will bee here tomorrow
Thanx again guys for all the info - Hopefully thats all i need , we shall see
Siberian Huskies
Re: A01 Light Package [Re: bee1971] #383275
07/28/09 07:42 PM
07/28/09 07:42 PM
SF Bay Area, CA
SF Bay Area, CA
