Re: ao1 light package
[Re: magnum440]
#383262
07/23/09 01:36 PM
07/23/09 01:36 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
While were on the subject
Anyone have the wiring diagram like posted for a 1971 Charger Superbee A01 Light Package - All the books and wiring diagrams i have , nothing
Trying to figure out my Ignition Key Lamp Yellow wire thru steering column not connected to anything
Thanx Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: A01 Light Package
[Re: magnum440]
#383264
07/23/09 02:24 PM
07/23/09 02:24 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
M15-18P? Is that M5-18P referenced on that wiring diagram? If so, that should be the unswitched (constant 12v) accessory power tap coming of the main dash harness, and should be fuse protected at the box. Should be a red colored flat three position female bullet type connector on a pink wire. How does the time delay relay work? The relay needs constant 12v on the pink wire (X1A-18P), when grounded on M6-18Y*(via the left door dome lamp switch) you should have 12v out on J5-18Y, to illuminate the ignition switch, for a minute or two then go out. There is a bi-metal spring contact that is heated up to provide continuity to the light, even after the ground is removed (door closes) it takes some time for the spring contact to cool down and open the circuit. Sometimes the relays can be easily repaired if inop. Carefully remove the cover check and clean the contacts. If the heating coil is open, may have to find another relay. bee1971, the relay/key lamp system had a separate wiring harness on the b-bodies, and with the relay itself was taped to the dash harness close to the ignition/turn signal connectors. If the relay and harness is present there should be a corresponding single connector on a yellow wire for the lamp lead. From the 72' FSM
[Re: 72roadrunnergtx]
#383266
07/23/09 09:55 PM
07/23/09 09:55 PM
bee1971
Sobieski Wi
Thanx man
I will look into the seperate wiring harness/relay and see if its there
If its not , i am sure that would bee fun to find
Thanx Scott
